G35 Compression Rods are Total Crap
Old Jul 7, 2007 | 05:40 PM
bocatrip's Avatar
I have a 04 Coupe with 22,000 miles and my girlfriend's 06 sedan has 14,000 miles. Both cars have creaking coming from the front end which can be heard going up and off driveways. I've just noticed my creaking and I have 2 months left on the warranty. The compression rod is over $300 for the part alone and the noise usually develops after 20,000 miles. I never have my radio on so I hear everything. I had a G35 loaner that had more creaking than I could handle in the few days of driving. Again, we have another annoyance and expense on a car that is supposed to be reliable. I have tolerated the weak paint, brake dust and premature pad wear, rattles, distorted front end geometry causing inside front tire feathering as well as premature middle tread wear on rear tires, and now creaking from the compression rods that makes the car sound like an old beater. There have been numerous threads about the bushings on the compression rods, but when a 14,000 mile 06 sedan has the same issues I feel that this is all getting very old.
Old Jul 7, 2007 | 09:42 PM
trey.hutcheson's Avatar
Moved to Suspension forum.
Old Jul 9, 2007 | 08:51 AM
Q45tech's Avatar
Compression rod [tension rod] sets the caster while forming a stiffening triangle between tie rod end, lower arm and rod.
Old Jul 9, 2007 | 10:03 AM
wreckeds2k's Avatar
no crap, My wife hates her car because of the popping it makes all the time
Old Jul 9, 2007 | 12:48 PM
dklau33's Avatar
Yup I've had the compression rod squeak for quite some time now. And having the dealer replace it only delays the inevitable. Spraying some silicone based lubricant on the bushings will quiet them down but it only lasts for like a week before the squeaks rears its ugly head again. Only solution I can see is to replace the bushing with something else. Too bad the Nismo set doesn't replace that one in particular.
Old Jul 24, 2007 | 04:11 PM
Jeff92se's Avatar
Red Card Crew
Any progress on a solution? I'm way out of warranty and the noise is killing me
Old Jul 24, 2007 | 05:12 PM
absolutg's Avatar
workin...
i had mine replaced at around 12k miles. not looking forward to it coming back but i will have to get infiniti to warranty it each time. i hope they come up with a solution to the problem.
Old Jul 24, 2007 | 06:34 PM
erdog's Avatar
I have the right side compression rod on order. Supposedly, the rod has been redesigned. It has a new part number supposedly.
Right side: 54468-AC70F $148.38
Left side: 54469-AC70F $148.38
"Infiniti has had a design change and the correct parts are being sent to you."
That's from autopartspeople.com
So I'm waiting for it to come so I can get rid of my noise. I wish my noise was only a creaking. Mine is a rattle and hopefully, I have diagnosed it correctly and the new compression rod will solve the issue.
Correction: Sides corrected for part numbers
Old Jul 24, 2007 | 07:49 PM
absolutg's Avatar
workin...
when i go home tonight i'll compare the part # with the ones i had replaced and let you know.
Old Jul 25, 2007 | 02:35 AM
Dan_K's Avatar
What part on the car are you guys referring to?
Old Jul 25, 2007 | 02:45 AM
erdog's Avatar
Just refer to this thread:
https://g35driver.com/forums/brakes-suspension/165833-suspension-noise-help.html
Old Jul 29, 2007 | 12:06 PM
Noremac's Avatar
Left side: 54468-AC70F $148.38
Right side: 54469-AC70F $148.38
Yes, those are different part numbers than what I had replaced in Dec 2005 (which were 54468-AL511 & 54469-AL511).
Did you order the genuine Nissan part from this outfit? We would all be VERY interested to hear more about this so-called "new" part. Please keep us informed!!
Old Jul 30, 2007 | 02:34 PM
erdog's Avatar
The part numbers I posted are supposed to be for the new updated part. They are being shipped today...supposedly
Old Jul 31, 2007 | 03:10 AM
Jason@Riverside's Avatar
please done pay retail!
PM me your ZIP and the part you need!
Old Jul 31, 2007 | 03:54 AM
absolutg's Avatar
workin...
jason, can you confirm that the compression rods have been "updated"?
