G35 & G37, Coupes & Sedans
service engine soon after oil change *HELP*
Old May 7, 2009 | 06:23 PM
crazeejitt's Avatar
I just got my oil changed yesterday it was at a new place around here and I do not think they work on many infinitis anyways the service engine soon light came on today I have probably only driven 20 miles since the change. is there something I need friend suggested something about resetting the oil thing(I have no idea what he said. I tried to call infiniti but they are closed I am typing this on my iPhone I have no Internet right now but I do need to drive to Tampa Saturday the problem is getting there with that light on will worry me. if anyone could help me I will check this post later but you could email me a
suggestion I'd appreciate it crazeejitt@gmail.com
thanks
Old May 7, 2009 | 08:03 PM
dave's Avatar
I know it sounds weird, but check to make sure that your gas cap is on tight.
Old May 7, 2009 | 08:11 PM
crazeejitt's Avatar
I did about an hour ago. still on 1 thing tho my sister just pointed out that there are tiny oil spots in the garage but the light has never been on before . I'm definitely taking it to the infiniti dealer when I go up to Tampa. unfortunately the infiniti dealer is about 2 hours away
Old May 7, 2009 | 08:58 PM
marcinr's Avatar
20 Year Member
Before you do your drive, make sure to check the oil level, since you'll wreck the engine if it's low and losing oil. In fact, bring some spare oil with you to top off on the way. I've never run my G35 low on oil, so I don't know what the low oil indicator is, but it could be the check engine light.
If your car is dripping oil, it's one of three things.
1) The oil drain plug isn't in tight enough or missing a washer.
2) The oil filter isn't screwed on tight.
3) The oil cap on top of the engine is missing and the oil is spurting out the top.
Old May 7, 2009 | 09:13 PM
crazeejitt's Avatar
thanks man I will definitely check all those things for sure and bring some oil with me thank you so much for the suggestion
Old May 7, 2009 | 10:13 PM
EL-EE-ES's Avatar
make sure that they put on an oil filter that works with motor
Old May 7, 2009 | 10:36 PM
crazeejitt's Avatar
thank you so much apparently the dude is an idiot (u can't imagine all the swearing going through my head right now) the oil
is leaking all over the place so I'm taking it in to nissan tomorrow thanks for all the help
Old May 7, 2009 | 10:46 PM
Gr8speed68's Avatar
Make sure u carry extra oil b4 u get it infiniti in case it eats it...geez i hope u get it there good luck
Old May 7, 2009 | 11:10 PM
crazeejitt's Avatar
nah man my dad has some hes bringing over tonight just so I can get to nissan about 13 miles from here so I can get the oil changed and see what the idiot did wrong. now since I know the problem I don't need to go to infiniti. once again thank you all for the help. I'll be sure to post up tomorrow when everything is okay. it's killing me inside like my baby(my g35) is bleeding
Old May 7, 2009 | 11:18 PM
EL-EE-ES's Avatar
also check to see if they put the dip stick back on right...
Old May 8, 2009 | 07:52 AM
uf20wop's Avatar
ugh that sucks man
this is why i do my own oil changes
fuccccck that
Old May 8, 2009 | 11:55 AM
crazeejitt's Avatar
some things I found out :1st last night I was scared the oil was leaking when I saw all the oil under my car, checked the dipstick, it was the old oil the moron didnt clean up when he changed it. 2nd thing I went to nissan today about 12 miles from my house, payed $47.50 for them to tell me "238 DIAG TIME FOUND TO HAVE CODE PO444 PURGE VOLUME CONT/V" nissan said it would not hurt to drive it but in order to get it fixed I will have to drive to tampa to the dealer. Happy to find out that it is not an oil leak, kinda pissed I have to waste time in tampa. So I am going to do some searching around to see exactly what this PO444 Purge code is, the service engine soon light is still on after they reset it. but thank you to all for helping. and yes I am changing my own DDDAAMMMNNN OIL FROM NOW ON (when i learn how)
Old May 8, 2009 | 01:38 PM
LightsOut's Avatar
SIETESG
i would call back the shop that did your oil change and explain to them what happen and make them pay or repair the cost of your engine code problem.
Old May 8, 2009 | 03:34 PM
Philly_G35's Avatar
I don't think it has anything to do with your oil change. I just Googled the code and found this. http://www.bba-reman.com/content.asp...ssan_dtc_po444
It has something to do with you evaporator canister. Did you try tightening the gas cap as earlier mentioned. Also maybe reset your ECU to see if it throws the code again.
Old May 8, 2009 | 05:01 PM
Canadian's Avatar
Canada, eh?
You know you can go to autozone or pep boys and they will pull the code for FREE right? No offense but its your own fault for going to the dealer to get the code pulled. That is no ones fault but your own.
Th611
Oct 27, 2015 03:48 PM
wuppiedog
Aug 7, 2015 11:16 AM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
newbdriver01
Jul 15, 2015 06:10 PM
