G35 & G37, Coupes & Sedans
2005 G35 Oil change question
Old May 19, 2009 | 01:34 PM
COMMANDOE's Avatar
New owner of sweet 05 G35 coupe! thank you thank you..... LOL anyway previous owner didn't have owners manual which is only like 80bucks to replace used! Anyway i do most of own maintenance but have no specs. How many quarts does it take for oil change?
thanks alot!!
Old May 19, 2009 | 01:36 PM
Nightm4re's Avatar
5 quarts.
just did my oil change
Old May 19, 2009 | 01:38 PM
COMMANDOE's Avatar
THANKS
Old May 19, 2009 | 09:01 PM
Blue Dream's Avatar
I drove ttrank's car solo
Make sure you have a little extra. Sometimes I need to add a little more than 5 quarts for some reason.
Old Nov 13, 2010 | 09:39 AM
06MTBarber's Avatar
More than 5 quarts
Resurrecting an old thread in hopes that I won't have to start a new one...
You said you sometimes have to add more than 5 quarts? I did my oil change on my 06MT Coupe yesterday, and added exactly 5 quarts (I know it was exact b/c it was a brand new jub of mobile 1) and it isn't even halfway up the dipstick!
I just went in for an OC test earlier in the year, and they may have tampered with my dipstick/oil pan so I'm really interested to hear from anyone who has had to add more than 5 quarts to theirs. This is become quite the mystery...
Old Nov 13, 2010 | 03:47 PM
blazeplacid's Avatar
I think he meant a little more in terms of 1/2 quart when changing the oil and filter
anymore than that is very odd if done at the inital oil change
how far after the oil change did you need to add more?
Old Nov 16, 2010 | 04:39 AM
Blue Dream's Avatar
I buy the larger filters for the FX45 and the 5.25 QT jugs of oil and it fills the dipstick to just short of the full line.
Old Nov 18, 2010 | 03:11 PM
richardcvan's Avatar
how often should you change your oil filter?
Old Nov 18, 2010 | 03:13 PM
easiest way is to just do it with an oil change
so between 3-5k miles
Old Nov 18, 2010 | 03:33 PM
okay thank you.. i do an oil change every 3k miles i guess i will change the filter every other oil change
Old Nov 18, 2010 | 05:23 PM
jibberjabbers's Avatar
No! The oil filter should be changed every 3-5k...
Old Nov 18, 2010 | 05:30 PM
thescreensavers's Avatar
Mr.202?
This is normal actually, Your filter you bought has a bypass valve. So once you turn on the car it will fill up with oil. The OEM sized filter can hold up to ~.3 quarts of fluid.
When you turn off you car the oil pressure drops, so the filter's bypass valve holds in the fluid.
The Cross hatched area on the dipstick is only 1 quart. So you need to add a bit more of fluid to bring it up to H. But Yes you have 5 quarts of fluid in there.
If you buy the M45 Filter and add 5.25 quarts of fluid it will get you right at or under the H line.
laksjd84
Feb 28, 2026 01:58 PM
ClwMike
Jul 23, 2015 12:55 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
newbdriver01
Jul 15, 2015 06:10 PM
