G35 & G37, Coupes & Sedans
stupid question about jacking up a car
Old Jun 24, 2009 | 12:00 AM
G35ftw's Avatar
Is it safe to completely jack up a car using 4 jack stands? I want to paint my rims this week. If this method is not recommended, is there anything I can buy that won't break my wallet?
Old Jun 24, 2009 | 12:27 AM
BuckeyeInMI's Avatar
It's totally fine. What I would recommend doing is get the front on jack stands, then the back, and then jack up one side of the front again so it just comes off the stand and then slowly drop the car back onto the stand. Do it for both sides. It's not necessary, but this will put the car squarely on all 4 jack stands.
Depending on how long it's going to be jacked like this, you should think about giving a little lift to each corner's suspension so it's not fully stretched out for an extended time. Jack up each corner maybe half way and put a wooden block under it to keep it lifted. Don't worry, the wood only has to support each corner's unsprung weight, minus the wheel/tire. I'd do it if you're going to have the car on stands for more than a day or so. This may be overkill, but no point in stressing anything.
Old Jun 24, 2009 | 12:29 AM
gary c's Avatar
With good jackstands it's safe. Check your manual for correct position of the jackstands and always leave your floor jack in contact with the frame just to be safe....something I do living in CA. we can always expect a 7.0 shaker....
Gary
Old Jun 26, 2009 | 08:20 PM
culi's Avatar
Man. I never thought of that till now. How dangerous it is have the car on jack stand, you underneath, and a 7.0 magnitude earthquake.
Old Jun 26, 2009 | 10:06 PM
johnhanson007's Avatar
I love it when my car gets jacked up.
Old Jun 28, 2009 | 05:12 PM
Mustang5L5's Avatar
If you are smart, it's pretty safe. If you put your car on level grouns and the jackstands are level and the seat is on a stable location on the car, then the stands are pretty solid.
I've been under cars with 4 jackstands doing you name it...installing tranmissions, axles, pretty much everything you can think of. The car's weight helps keep everything pretty secure provided you don't do anything stupid.
Still, i don't want to stay under one during an earthquake
Old Jun 28, 2009 | 10:38 PM
pwebb's Avatar
not only is making sure you have a good solid jack stand and using the correct jacking spot on the vehicle important, make sure you are placing the stand on a solid, stable surface.
just keep in mind that asphalt isnt as solid as you may think. I have left some pretty good jack stand shaped impressions into black top during a warm summer day in Houston.
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
Blakearold
Aug 27, 2015 12:37 PM
DRG35R
Jul 31, 2015 10:23 AM
mushu
Jul 15, 2015 03:55 PM
EasySausage
Jul 14, 2015 11:17 PM
