G35 & G37, Coupes & Sedans
need help with a few parts
Old Jun 24, 2009 | 12:45 AM
g35ryder19's Avatar
hey guys im currently modding my g. so far i have debadged it, greddy evo2 exhaust with topspeed test pipes, and a jwt popcharger with ztube on its way in the mail mite be going with helix test pipes to get better sound. but have a few questions
1 i wanna lower my car but not to where i needa camber kit so what springs woul you guys recomend???
2, i wanan get a set of sways and a strut bar which combo should i go with plz help
Old Jun 24, 2009 | 03:13 AM
TantoG35's Avatar
i wanna know the same thing???
Old Jun 24, 2009 | 05:33 AM
Dranom's Avatar
Springs you can probably go with eibachs, tein s techs, etc.... check their site for the drop
For sways i recommend hotchkis have it on my car and i really love it. takes out the body roll! For the strut bar i have gt spec. havent installed it yet coz i got the brackets powdercoated but some members say it helped a bit.
if you find some used gt spec front and rear tie that would help too
dont get the lateral bar coz it might hit the exhaust
Old Jun 24, 2009 | 06:31 AM
Blue Dream's Avatar
I drove ttrank's car solo
From what I've found out researching drops on this forum, any drop over 1-1.5" probably needs a camber kit. Anything under that you should be fine as long as you have a good alignment that follows a drop. I know my car is a sedan, but here are before and after pics of the Tein H Techs I put on last weekend. Doesn't look like I will need a camber kit. The coupe might be a little different, it sits lower than the sedan stock. I went from a 4 finger gap to a 2 finger gap, and the car will drop a little more as the springs settle. Looks more dramatic in person than on the pics.
Old Jun 24, 2009 | 12:56 PM
g35ryder19's Avatar
ok im deff gonna go with the hotchkis then and ima look up the springs as well
Old Jun 25, 2009 | 03:03 AM
TantoG35's Avatar
it looks good are you acraping at all yet what do you think if im getting a lip how much of a drop is this
Old Jun 25, 2009 | 03:31 AM
Dranom's Avatar
you wont scrape with that height unless you plow a driveway or dont slow down on a dip
Old Jun 25, 2009 | 06:01 AM
Blue Dream's Avatar
Dranom's right. It only dropped the car ~1". I do have to be careful with steep driveways (go in at an angle), watch curbs and curbstops (I clear most standard height curbs just barely), and take it easy over speedbumps. Other than that drive normally.
Old Jun 25, 2009 | 09:58 AM
gary c's Avatar
Truth and Advice....!
Let's make something very clear about lowering our cars! It doesn't matter which springs you use or if you lower it even 3/4" you're going to need adjustable a-arms/toe adjusters to bring your alignment back to OEM specs. Nissan designed our cars with very little adjust ability in the suspension thus causing the need for the above mentioned parts. You could go without them if you don't mind buying tires yearly which with the cost isn't smart!
Sway bars, I like Stillens sways cause they're adjustable and along with my endlinks my coupe takes high speed turns flat with zero body lean. Upper strut bars, for the price you can't beat Richie's upper strut bar....anywhere!
Gary
Speck102
Mar 26, 2018 11:48 AM
Greg Huston
Sep 25, 2016 11:36 PM
DarkLyter
Jul 28, 2015 04:57 PM
