G35 & G37, Coupes & Sedans
a little more power needed
Old Aug 5, 2009 | 11:05 AM
gary c's Avatar
Originally Posted by SDGenius
you can pick up 16hp w/a tune from stock... re-tune's only $150 after the initial tune. if he's on a budget and wants gains now it's an option and why would he get HFC's when he said he's catless already???
Because they have inspections in Oregon too, just trying to keep this new member legal and out of the impound yard.... 16 HP gains stock with just a tune....seriously doubtful!!!
Gary
Old Aug 5, 2009 | 02:30 PM
SDGenius's Avatar
^^^http://www.technosquareinc.com/g35sedan.htm
Old Aug 5, 2009 | 03:11 PM
danielrhine's Avatar
my car is already pretty illegal so that doesnt really matter and if your talking about a pro tune, i have to buy a access port first and dont see that really being worth and then the tune is 400
Old Aug 5, 2009 | 09:32 PM
BuckeyeInMI's Avatar
Originally Posted by blaccG35
^hey i member asking Tony bout it and he said the Copper ISO you dont need to adjust the CCV cause you have the Copper
That's true, but there's an even better option, and that's having both installed. Each option has it's pluses and minuses.
CCV Pro: Allows for a totally unheated throttle body and plenum, which is ideal in the summer.
CCV Con: You have to monitor the outside air temp, pop the hood to change the flow, plenum is heated when "on".
Cu ISO Pro: Isolates plenum from throttle body so plenum is never heated, never have to pop the hood.
Cu ISO Con: Throttle body is always heated.
The ideal setup is to have both because you get all of the Pros and none of the Cons, a Copper ISO so the plenum is never heated, and a CCV so you can stop heating the TB in the summer. You might have to open the hood a few times a year. Turn on the flow in the fall, and turn it off in the Spring once the weather warms up.
Old Aug 5, 2009 | 09:59 PM
shockedimpy's Avatar
When you say TUNE are you referring to a TUNE-UP? And $400 for a tuneup?! I was thinking around $150ish for one..Am I correct? Where would you go to get a nice tube-up anyways? Infiniti Dealership
Old Aug 5, 2009 | 10:19 PM
SDGenius's Avatar
no, like an ECU tune
Old Aug 5, 2009 | 11:01 PM
MJ-G35's Avatar
^ So are your talking about getting the ECU re-flashed?
If so I know a really good place, Injected Performance. Mail it to them and they will send it back to you re-flashed. www.injectedperformance.com
Old Aug 5, 2009 | 11:31 PM
A tune is more precise than just a reflash. A reflash takes your current setup and guesses at what is optimal and flashes for that. But 2 cars with the exact same bolt ons will have slightly different responses to a predetermined flash. They'll both be better off, but a tune is a live performance kind of thing, where small adjustments are made to fit the tune to the specific car. It costs more to get a tune, but you get more out of it.
Old Aug 6, 2009 | 12:17 AM
MJ-G35's Avatar
So you talking about a dyno tune? Where you put it up run it a few times, open it up adjust your A/F or whatever, then run it on the dyno a few more times. That kind of full tune?
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
sahizzle110
Jul 29, 2015 11:36 AM
