G35 & G37, Coupes & Sedans
Shudder when switching from drive to reverse, and vice versa
Old Aug 12, 2009 | 12:45 PM
PublicEnemy's Avatar
Like the title says, sometimes when I switch from drive to reverse or vice versa, the car will shudder when I turn the steering wheel right, usually only lasts about 2-3seconds but it feels like the car is going to stall.
Car is 07 coupe w/ AT.
Any ideas?
Old Aug 12, 2009 | 01:32 PM
atn_chargers's Avatar
I was wondering the same thing. This is the same thing that happens with my coupe. In reverse...and I put it to drive. As I turn my steering wheel...I feel a weird vibration. But then it goes away. Anybody have any ideas on what could cause this?
Old Aug 12, 2009 | 07:14 PM
Yes, this is the EXACT same thing happening to me...
Any input would be appreciated.
Old Aug 13, 2009 | 03:08 AM
marcinr's Avatar
20 Year Member
I don't know for sure what the problem is, but I can venture a couple of guesses.
First, when you are switching between forward and reverse, the car's not moving. If you're turning the steering wheel at this time, you're working the power steering pump really hard. In my car, I notice RPM's drop from this fact alone, even in neutral.
Second, when switching between gears, the transmission is flipping all sorts of solenoids, rerouting fluid, etc. This also puts a load on the engine.
It sounds like those two things together could be a bit much for the car to handle at idle. Add a tiny bit of gas, see if it makes the shudder go away. I can't test this myself since I have a 6MT.
Old Aug 13, 2009 | 03:21 AM
j 4 lD's Avatar
I have this same exact issue. The slower I go the less the vibration/shudder is. Any one?
Old Aug 13, 2009 | 09:21 AM
OBG3506's Avatar
Ditto, my coupe has been acting wierd when im putting it in gear, i really hard hit
Old Aug 13, 2009 | 09:24 AM
pinkii's Avatar
I think there is a TSB for the rear axle to be tightened. Mine makes a noticeable "shift" and its driving me crazy.
Old Aug 13, 2009 | 08:43 PM
bump for more input.
Old Aug 14, 2009 | 04:37 PM
It was my power steering drive belt. It was cracking...
After only 20k km too...
Old Aug 14, 2009 | 06:05 PM
WTF are you serious!!!?? How did you find out? And do you need to replace immediately?
Old Aug 15, 2009 | 09:31 PM
Took it to the dealership.
Cost like 80bucks for them to do it, probably like $30 for the drive belt itself.
I would get it taken care of sooner rather than later. Mine was pretty cracked, looked like it was about to come loose resulting in a lot more than $80 bill.
Old Sep 26, 2009 | 06:27 PM
spfmg35's Avatar
bump for more input. Mine shudders too, what does this power steering belt look like and where can I find it?
chinee
Jun 10, 2024 07:48 PM
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
leo38cheng
Interior
Aug 18, 2015 06:30 AM
