G35 & G37, Coupes & Sedans
WTF! ~ Help
Old Aug 19, 2009 | 07:46 PM
blkgurlblkcar's Avatar
Exclamation WTF! ~ Help
I was driving my G35 tonight, and a corny Acura was in my way. I blew past and then went around a curve. Well when I pulled into my garage the following lights were on ABS - Slip - and VDC off. What happened? That little speed broke my baby??? Does it really need to go the dealership? Have you ever seen this happen? Im scared
Old Aug 19, 2009 | 07:51 PM
OCG35's Avatar
^^^ it means Acura's are great cars. I've owned some and would buy again.
As for the slip lights - after you turned off the ignition, have you turned back on? Often times the slip light will stay on until you turn off then on again...
Moral of the story - dont rag on Acura's they are great cars.
Old Aug 19, 2009 | 07:55 PM
mackinboi's Avatar
lol ^^ acuras are great and reliable as well. better resale value. but i still Love my G.
Old Aug 19, 2009 | 08:05 PM
izzueeek's Avatar
^^ most of the acuras are not made in japan tho... i still think cars(like g35) from japan are more reliable
Old Aug 19, 2009 | 08:22 PM
Ok Acuras are hott too. What's wrong with my G??? :-(
Old Aug 19, 2009 | 08:26 PM
cremaster's Avatar
so, did you turn off the car and turn it back on? same deal? maybe you hit the VDC button on accident?
Old Aug 19, 2009 | 08:47 PM
thescreensavers's Avatar
Mr.202?
Check your brake fluid.
Old Aug 19, 2009 | 09:21 PM
Turned the car off and back on, none of those lights came on. Will check brake fluid too. Thanks
Old Aug 20, 2009 | 02:03 PM
OCG35's Avatar
Since the lights are out, nothing is wrong… like I said – sometimes when traction is lost the slip light will stay on until you turn ignition off then on…
Old Aug 20, 2009 | 02:11 PM
Thank you!
Old Aug 20, 2009 | 03:54 PM
gary c's Avatar
Aren't most Acura's FWD, I know there's the RL that's AWD which I would enjoy but the only one I could get serious about would be the NSX. They're so cool, even for a Honda....
Gary
Old Aug 20, 2009 | 04:01 PM
DiGil's Avatar
I drove G2 Integras for years, those engines and trannys are bulletproof. Gotta give all due respect to Hondas.
Old Aug 20, 2009 | 04:16 PM
Deezflip's Avatar
That's what you get for blowing pass that "corny Acura". That Acura is probably just cruising home, laughing at you while you deal with the ABS Slip VDC problem. Where you instigating something with it?
Old Aug 20, 2009 | 10:02 PM
code2424's Avatar
I had a acura rsx very good car I love the transmission there feels way better than the G's. But rwd owns.
