ABS, VDC Off, SLIP light all ON
Old Jan 13, 2009 | 03:20 AM
VISHAL_G35's Avatar
Exclamation ABS, VDC Off, SLIP light all ON
ABS, VDC Off, SLIP light all ON and my car will not let me shift it into DRIVE, it is stuck in PARK until I use the shift lock key and put it into drive. All of these lights are currently on...
I know this has happened to many of you in different instances... I have done the searches ... however not many of you have had the "shift lock issue"
Also, in the searches nobody has come to a conclusion on what the problem may be.
From the previous posts I gathered these possibilities and assumptions:
- Replace the 10A stop lamp fuse.
- Throttle Body
- brake fluid level low
- brake pads low
- brake switch (intercontroler?)
- throttle body
- ABS system?
I am looking for a more definite answer. I would like to know if anyone has had this problem and if it has been dealt with. If so, what exactly was the problem?
If you took it to the dealership, did they tell you what the problem was? also, was it expensive to fix?
Old Jan 13, 2009 | 09:59 AM
cuong's Avatar
lol i have all of those 3 lights on as well after i installed my coils and camber kit. redid the camber kit 3 times and light still stays on. i can't seem to figure out myself.
Old Jan 13, 2009 | 10:08 AM
PAIXAO's Avatar
Last thread I saw with these problems with the shifter locked we recommended that the owner have it towed to the dealership. I don't recall seeing an update.
Might want to try searching and shoot him a PM. It wasn't all that long ago, within a month...
Old Jan 13, 2009 | 10:14 AM
S E G A's Avatar
brake pads low
check it first of all
Old Jan 13, 2009 | 12:25 PM
V35 Skyline GT's Avatar
6MT Coupe
^ Exact same thing on a friends 350Z. All good now after topping off...
Old Jan 13, 2009 | 04:07 PM
Canadian's Avatar
Canada, eh?
Originally Posted by Princess_Jen
I had an issue w that. Brake fluid was barely below the min line.. just added some and all the lights turned off.
+1 I had the same issue, and many people have too.
Old Jan 13, 2009 | 05:48 PM
trung_n_nguyen's Avatar
Maybe I can help U here. It happen 2 me once, all the light came on, blinking, couldn't put car into drive, and when I tried to accelerate, the car doesn't move. I towed it to the dealership and this is what happen.
1. My battery died.
2. Something happen 2 my alternator.
Make sure U check that out. Alright dude.
Old Jan 15, 2009 | 01:09 AM
VISHAL_G35's Avatar
Just to fill you guys in on the actual problem... hopefully this will help people in the future...
After taking the car to the dealer, the Conclusion:
the problem was the brake fuse ... it also somehow short circuited the wires to my brake lights...
the cost: $328 dollars...
Old Jan 15, 2009 | 01:24 AM
absolutg's Avatar
workin...
the wheel sensor probably needs to be adjusted on that bracket.
Old Jan 15, 2009 | 01:32 AM
Sponger's Avatar
6MT Brembo Coupe
You need to get an alignment. Your camber and toe is way out of whack after the toe bolt and camber kit install. This will fix the VDC and slip lights. You're probably going sideways down the road.
Old Mar 17, 2009 | 01:41 PM
Jay87's Avatar
ABS problem
My car has all those 3 lights on too. I knw the problem though. wut u need to change is the ABS sensor..all those lights will go away..I m %100 sure..
Old Mar 18, 2009 | 06:51 AM
Jay87's Avatar
Wutt?? if the brake fluid is low,only brake light will come on..i m an automotive technician and i work on my own car..i know wut i m talkin abt
