G35 & G37, Coupes & Sedans
Ichiba Front Camber Kit Help and Components
Old Sep 2, 2009 | 12:43 AM
bigdano's Avatar
Hey guys I bought a "new" Ichiba front camber kit... if anybody else has put this kit on, can you help me?
The guy sent three rubber bushings-
Two small ones and a larger one that fits over one of the small ones. The bushings slide on to the bolt.
1. Does anybody know where I can get one of these larger bushings that fit over the smaller ones on the bolt?
2. Do I really need all 4 bushings or can I rig it up different???? (I only have three bushings and I believe the kit comes with four) (Seller left me hangin' )
Picture of all components are below (NOTE: Pictured are only TWO of the rubber bushings sent. I have a total of three rubber bushings. I am missing the one of the larger rubber bushings for the other A Arm. Also pictured is the spacer)
Putting on the smaller bushing:
Putting on the larger bushing:
Putting on the metal spacer:
Putting on the nut:
Am I putting all of these on right? Any help is appreciated...
Old Sep 2, 2009 | 12:52 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
pics?
Old Sep 2, 2009 | 12:57 AM
j 4 lD's Avatar
PICS please. I'm getting ready to put on a front camber kit myself soon.
Old Sep 2, 2009 | 12:59 AM
bigdano's Avatar
Pics are up... I need to know if this is the proper way to set it up... and if so where can I get an additional larger rubber bushing because that guy failed to send it!
Old Sep 2, 2009 | 01:07 AM
doesn't look too new to me. I've installed a set of Ichiba front arms and the bushings were already in place, just bolted everything up.
-GP-
Old Sep 2, 2009 | 01:13 AM
bigdano's Avatar
-GP-
It certainly was NOT new... however I am weighing my options because seller already refunded me $10.00 for bad paint because he didn't package it at all when it was sent.
Anyway I am just looking for answers to my questions above... thanks though.
Old Sep 2, 2009 | 02:59 PM
LightsOut's Avatar
SIETESG
yup not new...
my ichibas came with everything attached. my mechanic just picked them up and installed.
fyi
If your dropped about an inch or more, send them back, as they wont get you back into oem specs.
Old Sep 18, 2009 | 09:25 PM
g3fly's Avatar
Ummmm that sucks because I just bought these same arms off "bigdano" and his post said new arms. Certainlly wernt new looking to me; or powdercoated just looked fresly spray painted. But anyways that sucks beacuse im lowerd waaaay more then a inch so I should get new ones? What kind should I get?
Old Sep 18, 2009 | 09:32 PM
DEEZBLUBALLZ's Avatar
Do the SPC ones get one back to factory specs if lowerd 2"? If so...get those.
Someone with some firsthand expierance will chime in....
Old Sep 18, 2009 | 11:04 PM
loki05's Avatar
same, I ordered brand new ichiba, all attached. seems like ur missing a bushing to be a complete kit.
Old Sep 18, 2009 | 11:36 PM
g3fly's Avatar
And the Ichiba's cant get modiffied to do more oem specs? like ream out the holes furthere out? Like have a machine shop do it?
Old Sep 19, 2009 | 12:08 AM
loki05's Avatar
ya I don't think ichiba will be able to handle your 2"+ lower. SPC or something similar should be able to work
jsimonk
Dec 22, 2023 03:49 PM
socalg35x
Aug 7, 2015 09:36 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
nascarbuff17
Jul 16, 2015 10:23 AM
djreinx
Jul 13, 2015 05:04 PM
