G35 & G37, Coupes & Sedans
Ipod Adaptor for my Coupe?
Old 09-09-2009, 08:29 PM
bigphill's Avatar
the amazon usa spec kit charges the ipod.
Old 10-22-2009, 03:08 AM
silentxnight's Avatar
ok quick update.
Ended up going with the usa spec pa15. Took me about 2 hours to do the install. Its pretty cool, and im glad i went with this instead of the fm tuner. The install was fairly easy. The hardest part was trying to figure out which cables go together and stuff. The installation guide confused me a lil bit lol. Quick question tho, for the people who have already installed. Where did you guys put the adapter box and the bulky wires? i tucked everything behind the head unit, but had to try several different ways before i could get the head unit flush again. Im kind of worried because its pretty packed in there, and im worried about it overheating. Is that an issue? or should it be ok with everything back there. I do have a nav if that has to do with anything, but i rarely use it.
Old 10-22-2009, 11:14 AM
av8or's Avatar
Originally Posted by silentxnight
ok quick update.
i placed the adapter box under the center console... the wires are long enough and there are more than enough space under there..
Old 10-22-2009, 02:36 PM
hmm how far under did u go from the center console? like underneath the seat warmer buttons and the 2 small *** cup holders? lol.
Old 10-23-2009, 12:17 AM
av8or's Avatar
yep....lots of space in there.. do you have a manual or auto?
Old 10-23-2009, 12:40 AM
i have an 07 manual. so you ran the wire through the stick shift area? How do u take out the cup holder tray anyways, do you just pull up?
Old 10-25-2009, 11:27 AM
Blue Lion's Avatar
I have the PA15 on my 07 auto coupe. The unit is behind the head unit, kind of straight ahead of the shifter, or behind the ashtray toward the engine. The wire runs to the glovebox. I only use my Ipod on long trips so I put it in the glovebox, connect it, and put it on shuffle.
Old 10-25-2009, 01:25 PM
^^ yea..thats pretty much where i put mine. except i stuck the ipod wire out the side of the head unit so its on the outside.
djreinx
Engine - Electrical
12-10-2015 01:48 AM
bishop977
Audio/Video/Electronics
07-31-2015 02:29 AM
BlackGee35
07-21-2015 07:24 PM
Quick Reply: Ipod Adaptor for my Coupe?
