G35 & G37, Coupes & Sedans
60K service... Infiniti rip off?
Old Sep 23, 2009 | 01:20 PM
nghiars's Avatar
Check on your invoice when you got your mototr replaced. It should include everything that was replaced along with it. They dont necessarily have to change fluids during the swap.
Old Sep 23, 2009 | 02:04 PM
infinitisport's Avatar
for $600 smakeroos???
tell them to throw in a lap dance... otherwise walk away,
Old Sep 23, 2009 | 02:08 PM
WILLIE BEANS's Avatar
https://g35driver.com/forums/g35-cou...e-service.html
click that link theres usefull information in there reguarding the 60k service ..
hope it helps ..
Old Sep 23, 2009 | 03:27 PM
uf20wop's Avatar
total rip
Old Sep 23, 2009 | 03:51 PM
oops sorry..
i guess i misread ..
bump for some help ..
Old Sep 29, 2009 | 03:49 AM
mw08G35S's Avatar
sure total rip, 60k you can probably get done for like 6.
but i mean any 60k service is a rip... shoot you should see what the lexus and mercedes rate is.
Old Sep 29, 2009 | 04:05 AM
officerdbag's Avatar
o Replace engine oil with Fully Synthetic Motor Oil and Nissan Oil Filter
Do an oil change
o Replace automatic/manual transmission fluid with Nissan S-Matic Transmission Fluid
You just got a new tranny installed back in december. about 10k miles ago, you're fine.
o Replace differential oil
You should do this one.
o Replace engine air filter with Nissan Engine Air Filter
You have an intake, you're fine.
o Replace engine coolant/flush system
You just got a new motor, and then a new radiator shortly after. You had this done not too long ago.
o Replace in-cabin microfilter with Nissan In-cabin Air Filter
This one is all labor, just do it yourself or go somewhere else
o Inspect all lights, tires, suspension parts/axles, brakes/pads/rotors/lines, exhaust, ball joints
You have pretty new tires, your suspension is all ok.. Your brakes are not even a year old. Your car is sound while driving.. Just had new springs put on.
o Replace all belts
This one is pretty much all labor too.. Have another shop that does cheaper labor do this.
Old Sep 30, 2009 | 04:40 PM
PTownG's Avatar
Rip.
If you had your engine replaced you have fresh coolant. if it's the original trans it's time for fluid change and differential too. That doesn't cost $600. Amsoil 4 qts trans and 2 qts differential will run about $80 and you'll need a $10 fluid pump
They have fram charcoal in cabin filters at walmart for $15 and it's a 10 minute job.
Really just check your work order from the engine replace. It lists eveything they replaced. I see coolant and belts on mine.
Old Sep 30, 2009 | 05:06 PM
Blue Dream's Avatar
I drove ttrank's car solo
Smart decision^^
Diff service and oil change is really easy to do if you, or you and a friend, would be willing to do it. Save you even more.
magnetism80
Feb 1, 2019 10:00 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
gatorglaze
Sep 10, 2015 12:03 PM
erich2780
Sep 3, 2015 03:23 PM
