G35 & G37, Coupes & Sedans
Idle RPM
Old Oct 2, 2009 | 05:42 AM
mistasleepi's Avatar
Idle RPM
Is 600/650 RPM to low? Car is a 2004 Coupe Auto.
Old Oct 2, 2009 | 09:50 AM
OCG35's Avatar
that's exactly where it should be
Old Oct 2, 2009 | 01:24 PM
thanks!
Old Oct 3, 2009 | 11:29 PM
puttrench's Avatar
mine is about 450 (03 auto coupe), how do I adjust it??
thanks.
Old Oct 3, 2009 | 11:39 PM
450 is pretty low doesn't your car feel like it wants to shut off at that RPM?
Old Oct 4, 2009 | 12:53 PM
OCG35's Avatar
thanks.
you wouldn’t be able to register 450 on the tach... the first increment is 500, then every dash after is 100 - are you sure you are reading it correctly? Or did you determine rmp from dyno or from something like Cipher software?
If you are seeing four and a half dashes from the bottom line, that’s 950 rmp (a little high).
Old Oct 4, 2009 | 01:04 PM
pwebb's Avatar
revolutions minute per?
you're probably right about his idle though.
Old Oct 4, 2009 | 01:16 PM
F5TG35's Avatar
how do you adjust your idle? anyone know?
Old Oct 4, 2009 | 01:22 PM
OCG35's Avatar
you can do it with Cipher... you need some sort of tuning software to adjust it yourself - there is no manual way to do it.
Old Oct 4, 2009 | 01:23 PM
OCG35's Avatar
you're probably right about hits idle though.
"hits" idle?
Old Oct 16, 2009 | 11:21 PM
puttrench's Avatar
its a canadian model and it idles at ~450 rpm..
any idea where to get "cipher software'?? steeler only maybe??
thanks.
Old Oct 17, 2009 | 02:30 PM
DRG35MIA's Avatar
thanks.
You can find it on the Uprev website.
http://uprev.com/products.php
Old Oct 17, 2009 | 02:56 PM
blazeplacid's Avatar
I agree, the tach starts at 500...unless the Canadian gauges are measured different
Old Oct 17, 2009 | 10:40 PM
pwebb's Avatar
"hits" idle?
fixed...
you might be able to get your dealer to adjust your idle for free if you're a frequent customer...
Old Nov 15, 2009 | 07:02 PM
Fetch's Avatar
I have an 06 manual coupe with single turbo and idles around 1200 but sits at like 2000 rpms when i first start it, that normal? I want to adjust it down.
