G35 & G37, Coupes & Sedans
*help*Painted lights. Plugged them back in. battery draining
Old Oct 7, 2009 | 03:45 PM
crazeejitt's Avatar
So I painted my headlights when I took them apart I took all of the lights out to bake them. Then I painted them and all that, put em back together hooked up they worked, checked my radio, started my car backed it out everything is good! A accomplishment I was so happy! So this morning I go to start my car and it doesnt start I can hear it trying, and I notice when I lock it I hear a "dim" horn sound not as loud as usual. I unplugged my lights and put a battery charger thing my dad had it was about 35% so I charge it up. to 90% it has been 90% for about 13 hours with the lights unplugged, so I am pretty sure something is shorting out in the lights that is causing the battery to drain. I checked all the connections the only 3 thing I could think of is 1:when I took apart the headlights I noticed that they grey box on the bottom was missing a screw in it but I didnt think it would cause the battery to drain. 2: maybe I got the headlighs and wires mixed up but I dont think this would be the cause because everything on the headlights were equal 3:I plugged in a cigarrite lighter (power plug) splitter while I had the headlights out but would this really cause it? I am very worried I think my best bet might be to drive an hour and a half to infiniti told them what I did, look like and idiot having them fix it. but I would LOVE and feedback that anyone has thanks. oh yeah if it helps its an 07 g35 coupe.
*UPDATE*:My car does start with the ciggarrite splitter and headlights unplugged, and the battery seems to be holding up with those 2 things unplugged. the horn also honks as loud as it used to when the car is locked
Old Oct 7, 2009 | 03:51 PM
blaccG35's Avatar
why dont you buy a new battery???
Old Oct 7, 2009 | 04:01 PM
crazeejitt's Avatar
is it just a coincidence that my battery just went bad as I was working on the lights? I have never had any problems with the battery before now.
Old Oct 7, 2009 | 04:20 PM
blaccG35's Avatar
maybe but im not 100% sure myself
Old Oct 7, 2009 | 05:16 PM
mrmeagle's Avatar
I would try hooking the lights back up, but leave the power plug splitter unplugged. See if the battery drains. If it does, then you know the problem is the lights, and can go from there (I'm sure someone here will have ideas of what to check). If it doesn't you know you didn't do anything wrong and it's the power plug splitter draining power. If that's the case you just need to make sure to unplug the splitter when you're not driving.
Old Oct 7, 2009 | 05:20 PM
F5TG35's Avatar
did you take off the grey box before you baked them?
Old Oct 7, 2009 | 05:48 PM
crazeejitt's Avatar
yes I did.
Old Oct 7, 2009 | 05:57 PM
BloodlineG's Avatar
haha... yah i would just replace your battery you probably need to anyway there cheap too.
Old Oct 16, 2009 | 12:04 PM
crazeejitt's Avatar
im an idiot some wire was grounded fixed it
chinee
Jun 10, 2024 07:48 PM
mann1961
Aug 9, 2015 08:44 AM
apintojr
Jul 23, 2015 10:52 AM
justgotg35
Jul 19, 2015 12:33 PM
