G35 & G37, Coupes & Sedans
Low Tire Pressure Question
Old Oct 10, 2009 | 08:08 PM
willis555's Avatar
For about a month or so, my low tire pressure light has been on. I have no idea why it is on because I have checked all four tires numerous times, and they are all within the 30-33 PSI range.
I did look at the tires though, and this is what the rear tires look like.
So, I was just wondering if the tread could possibly have anything to do with the low tire pressure light?
Thanks!
Attached Thumbnails Low Tire Pressure Question-dsc00363.jpg   Low Tire Pressure Question-dsc00364.jpg
Old Oct 10, 2009 | 08:22 PM
Neu Era's Avatar
Tread has nothing to do with the TPMS. Battery in your sensors is most likely your problem. I would go to a dealer nearby and see if it possibly a defect.
Old Oct 10, 2009 | 08:30 PM
willis555's Avatar
Yeah, I am taking it in soon for other reasons anyway.
On a side note, should I have my tires changed because of how bald they are? Or is it fine to keep them on?
Old Oct 10, 2009 | 08:50 PM
Neu Era's Avatar
I can't really tell in those pics, but u should definetely get them replaced at 2/32"
Old Oct 10, 2009 | 08:57 PM
willis555's Avatar
What is 2/32"?
Also, in both pictures, there is something that looks like a flap. Both flaps look like they are missing a screw. Or is it supposed to be like that?
Old Oct 10, 2009 | 11:36 PM
kentonio's Avatar
You need an alignment too bro. The way the tire thread is worn worse on the inner part of the tire is sign of this.
Old Oct 11, 2009 | 12:39 AM
marcinr's Avatar
20 Year Member
The inside of your tires being worn like that means that you're running too much camber or too much toe-out, or both. Get the alignment checked, and replace those tires before you skid out in the rain and hit something.
Old Oct 11, 2009 | 07:01 AM
Blue Dream's Avatar
I drove ttrank's car solo
Your driver side tire is showing the steel belts which is a blow out waiting to happen. Change those today, they are dangerous!!!!!
Old Oct 11, 2009 | 08:43 AM
RBull's Avatar
Rated M
Your tires were worn out 5000+ miles ago. Are you serious about asking whether they should be replaced? There is no tread and your belt is showing. That is highly dangerous to you and other drivers.
Get an alignment done at the same time. Have the TPMS checked out also.
Old Oct 11, 2009 | 08:48 AM
GEE35FX's Avatar
^^^^+! a person is endangering themselves and others by driving on worn out tires like that.
Old Oct 11, 2009 | 09:52 AM
Neu Era's Avatar
When the tread is measured less than or equal to 2/32"
Old Oct 11, 2009 | 09:54 AM
STCLAIRWEST's Avatar
You guys shouldve seen my friends S2000 after last winter, it was so bald the surface was flat as hell no tread whats so ever.
Old Oct 11, 2009 | 12:52 PM
Xet's Avatar
Xet
my tmps is doing the same thing... no clue as to why
Old Oct 14, 2009 | 08:52 PM
Andyl's Avatar
have any of you checked your spare tire if you have tpms your spare has on too because a friend of mine had the same thing and his spare was flat just an fyi.
Old Oct 14, 2009 | 09:21 PM
willis555's Avatar
I took my car in today, and they are replacing the tires and fixing some other things. I had no idea that these tires were that close to blowing out. I am glad I took it in.
Thanks for all the answers!
jsimonk
Dec 22, 2023 03:49 PM
Jnm07
Aug 6, 2015 03:03 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
