G35 & G37, Coupes & Sedans
Heater Core Help Please I need it.
Old Oct 18, 2009 | 08:16 PM
2005G35NYC's Avatar
Exclamation Heater Core Help Please I need it.
I looked all over other forums including this one and found nothing so i need some help.
PLAY x PLAY for 2005 G35 Coupe Auto 36K Miles
1.Bought the car Aug 2I
2.Drove the car Around no problems -- A/C Works Fine And No over Heating.
3. 2 weeks ago decide to use the heat in the car and notice that it blows cold air whiles idling. Heat works great whiles driving.
4. Did research and found out the most common problem can be air in the system.
5. One week ago i performed a coolant flush, removed the air release and did everything properly. Still the same problem.
6. Infiniti Dealership did a Coolant flush Yesterday. Still the same problem.
7. I am beginning to think that the heater core is clogged. I also hear a water noise every time i start up and drive.
Has any ever changed the heater core or performed a back flush on the heat core?
I need advice. Thanks.
Old Jan 7, 2010 | 11:35 AM
AidanP's Avatar
I'm going through the same thing right now. Did you ever flush the heater core?
Old Feb 24, 2010 | 11:25 AM
ERILUDE's Avatar
YOU DO NOT HAVE TO BLEED LINES OR DO FLUSHES!!!
This is the problem with the car, the radiator during cold times stays low and improperly pulls from the reserve. Let your car sit over night and then open the radiator and then fill up the radiator directly to the brim. DON'T FILL THE RESERVE. What happens is when you fill the radiator, then turn the engine on it creates suction that pushes the airpocket into the reserve and out of the lines. You may have to try it again the next morning inorder to make sure the radiator is full to the brim. But after that, you will never have a problem again!!!! I'm going 2 weeks str8 with not even a hint of cold air at idle, damn near cooking my *** at a red light lol
Good Luck to all!!!!
Old Feb 24, 2010 | 07:49 PM
gary c's Avatar
Just another "Old School" fix!
Had your Infiniti dealership done the flush correctly by letting your car run with the radiator cap off until warmed up and filling it to the top you wouldn't be having this issue! What kind of training do these receive?
Gary
Old Feb 24, 2010 | 10:47 PM
the_sedan's Avatar
you still have air in the system. do this for the generic method. find a funnel that will fit snug in the hole where the rad cap goes. mark where it fits nice and snug and cut the lower portion off so the tip isn't going deep inside the radiator. shove it down there and fill the funnel half way with coolant. let the car run until it is at operating temp so you know the t-stat is opened up. once it's warm, rev the car multiple times to 4k rpm or so....you will notice air bubbles will be circulating and come out from there. i had to do this to a G after i did a coolant service to it with my vacuum style coolant filler kit.
if you believe your heater core is clogged perhaps, backflush it. take the heater hoses loose and run a hose through the opposite flow direction for a few minutes to see if you flush anything out.
Old Jan 5, 2015 | 08:28 PM
jms0192's Avatar
heater core doesn't work
I'm trying to change the heater core, i know i have to take out the whole dash board. Does anyone have the blueprints of how to replace the heater core ? I already take out most of the dash but i still have somoe stuff to take out so please help me. Anyone who knows the steps
Old Jan 8, 2015 | 01:15 PM
telcoman's Avatar
Veteran: Army
Do a search for the FSM
Telcoman
Old Jan 23, 2015 | 05:14 PM
blue88aw11's Avatar
I'm also changing heater core on 2003 sedan automatic. The fsm is very vague for this particular process.
Old Jan 23, 2015 | 11:18 PM
jms0192's Avatar
I called the dealer and asked for the diagram of how to remove it. I recommend you to go to a specialist in the type of job. I did it my self and it toom 4 days almost 5 to finish everything. It's a very hard job.
Old Mar 16, 2015 | 12:40 AM
blue88aw11's Avatar
Was able to complete the job. Been a month and no issues so far. A lot more work than I thought it would be.
Old Apr 12, 2015 | 11:26 AM
Mr.GEE's Avatar
20 Year Member
If the heat works great while driving, as you say, chances are your heater core is OK. Perhaps it's the duct gate that diverts the air flow through the heater core. I'm not sure if it's vacuum activated or electric. I will look into the service manual and post back.
Old Apr 12, 2015 | 11:50 AM
Mr.GEE's Avatar
20 Year Member
The air mixing door is electrically operated and computer controlled if you have the dual control system. The dealer has to place it on the Consult II monitor to do a diagnostic run. Make sure when refilling coolant, you open the bleed valve on top of the heater hose and keep filling the radiator until coolant comes out of the relief valve.
Greg Huston
Sep 25, 2016 11:36 PM
joedaddy1
Jul 28, 2015 02:58 PM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
