G35 & G37, Coupes & Sedans
Radiator fan
Old Nov 9, 2009 | 06:34 PM
sfsergey's Avatar
Radiator fan
Hey guys I just picked up a 2005 coupe m/t and driving it I notice that the radiator fan is on while I drove most of the time 80% of the time, usually it should be on when idling for long periods but during driving? seems weird? anything I can check out or is this normal for G's? Thanks.
Old Nov 9, 2009 | 08:22 PM
volcom_koda's Avatar
Its funny you ask. I got a letter from from infiniti today, informing me that some (bout 10%) of radiator fans burn up in 04-07 models. This is not your problem, obviously, but i figured i would let you know that there will probably be a recall issued for this if yours burns up also.
As far as your problem goes, i think them running more often than other cars is normal.
Old Nov 9, 2009 | 08:41 PM
bigc's Avatar
Wings Nation
OP, you need to check your coolant level or find an OBDII reader to monitor your coolant temps. Anything over 208F will trigger your fans to turn on...you really shouldn't be over that temp for very long once your fans turn on.
A cheap way to see if you have enough coolant is to 1) check the level of coolant in your overflow, or 2) see if you get HOT air from the heater shortly after turning on the car when its cold. Variation/no coolant in the overflow when car is cold or no hot air from the heater when the car is cold usually means you have an air pocket. Air pockets can cause your car to run hotter than it should.
Old Nov 10, 2009 | 02:53 PM
sfsergey's Avatar
just out of curiousity how much coolant should be in the reservoir...no coolant?
Old Nov 10, 2009 | 03:04 PM
miltoda's Avatar
there should be coolant in between in the min and max markings on the reservoir.
Old Nov 10, 2009 | 03:09 PM
sfsergey's Avatar
ok great thanks, cause mine is bone dry nothing in the reservoir
Old Nov 10, 2009 | 03:16 PM
bigc's Avatar
Wings Nation
you've definitely got air in your coolant system then
Old Nov 10, 2009 | 03:40 PM
sfsergey's Avatar
Great, thanks guys big help, got a project for the weekend, it shouldnt be hurting the car to drive with air in the coolant right?
Old Nov 10, 2009 | 04:18 PM
miltoda's Avatar
Air will make the car run a little hotter than normal, just keep an eye on it. Read the coolant replacement procedure in the service manual and look at the procedure to remove air from the system. You may just want to go ahead and flush the entire coolant system while you at it.
Old Nov 11, 2009 | 12:47 PM
sfsergey's Avatar
when I turn the car off the fan turns off too, gonna flush the coolant, thanks guys
Old Nov 11, 2009 | 04:50 PM
spinna001's Avatar
I had the same issue. I did a flush and solved the problem. Follow bythebay DIY
BradMD_96
Oct 6, 2015 09:31 AM
Learned Hand
Oct 1, 2015 09:02 AM
lavtxa
Sep 21, 2015 11:51 AM
mattdg35
Sep 14, 2015 11:28 AM
