G35 & G37, Coupes & Sedans
is this needed?
Old Feb 1, 2010 | 04:19 PM
skizg35's Avatar
is this needed?
i have a 2004 g35 coupe put 3inch cat back , intake, and spacer.. i heard or think i may have read about reseting things after putting parts on these cars. any word?
Old Feb 1, 2010 | 04:32 PM
MJ-G35's Avatar
You talking about getting your ECU reflashed?
Old Feb 1, 2010 | 04:53 PM
skizg35's Avatar
yea.
Old Feb 1, 2010 | 05:00 PM
jibberjabbers's Avatar
No he's talking about resetting the ECU and then running to car to allow the ECU to pick up on the new crap he put on..
And yes, you should reset the ecu. Not sure how to do it on this car.
But on my S2k, I had to remove the ECU fuse for 10 mins. Then let the car run on idle for another 10 min with everything off. (AC, RADIO, Heater, whatever). Making sure I dont rev the car.. Then turn off the car and that was it.
It's a little more complicated on the G35. And I don't think you have to let the car sit on idle for 10min after the ECU reset. You just drive it?
Old Feb 1, 2010 | 05:13 PM
skizg35's Avatar
thanks man ...anyone know how to reset a 2004 g35 coupe ecu?
Old Feb 1, 2010 | 06:08 PM
MJ-G35's Avatar
No really sure, but I heard it was complicated.
Old Feb 1, 2010 | 06:10 PM
Blue Dream's Avatar
I drove ttrank's car solo
Easiest way is to unplug the negative battery cable for a couple of hours then reconnect.
Old Feb 1, 2010 | 11:00 PM
BuckeyeInMI's Avatar
Not sure on the reset, but your spacer should have come with instructions. If I remember, I unplugged the negative cable, then pressed the brake pedal 3 or 4 times to dissipate the caps. But you should think about a tune. Spacer and intake upgrades can be handled by a reset/idle learn, but adding the cat back starts changing things a little more radically. You won't really be optimized until you get a tune.
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
socalg35x
Aug 7, 2015 09:36 AM
Terry_G35
Aug 4, 2015 02:38 PM
bjo16
Aug 4, 2015 09:52 AM
newg37
Jul 26, 2015 09:32 AM
