G35 & G37, Coupes & Sedans
Is it my tank or the pumps??????
Old Feb 9, 2010 | 07:43 PM
Maxypad's Avatar
I've been noticing that recently every time I go to the pump and I'm filling up it always stops early and wont let me fill up all the way. And at first i thought it was the shell up the street had f'd up pumps cause its kinda old but then i noticed that really where ever i go its kind of like a coin toss if it works.
Any one had this problem or am just **** out of luck when it comes to pumps...
Old Feb 9, 2010 | 08:47 PM
PublicEnemy's Avatar
Two things:
Fuel level sending unit is fouling (which is common with our cars)
OR
There is something obstructing the flow of gasoline into your tank, making the pump think that the tank is full.
Old Feb 9, 2010 | 11:48 PM
gary c's Avatar
There was a recall on gas tanks having your issue. I believe they replaced the inlet tube. Call Infiniti and ask or do a SEARCH under gas tank issues here on Driver.
Gary
Old Feb 9, 2010 | 11:49 PM
BuckeyeInMI's Avatar
I've had this happen once or twice, but I realized that each time I'd left the car running while I filled up. Haven't done that since, and haven't had the problem since.
Old Feb 10, 2010 | 12:03 AM
speedracerg35's Avatar
not tank or pumps. breather vent that allows pressure to escape while filling the gas tank is not functioning correctly.
Old Feb 10, 2010 | 09:12 AM
cmesidewayz's Avatar
Mine does that too, when was the recall ? im out of warranty do you still think they will fix it?
Old Feb 10, 2010 | 11:26 AM
3rick35c's Avatar
Under Construction
yea i am on the same boat as you are and wondering the same thing???
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
BradMD_96
Oct 6, 2015 09:31 AM
Hogbone
Sep 28, 2015 06:44 PM
Claudiu
Sep 26, 2015 01:04 PM
