G35 & G37, Coupes & Sedans
how to debadge with a heat gun?
Old Feb 24, 2010 | 10:43 PM
itsgroll's Avatar
my friend has a heat gun that he is letting me use this weekend. I want to remove everything on the rear what are the correct steps and what chemicals do i use to prep/cleam surface before and after?
also...just making sure, everything IS glued on correct?? nothing is going to leave a hole is it?
thanks
p.s. a DIY would be nice
Old Feb 24, 2010 | 11:02 PM
Thisisastickup!'s Avatar
If you really want to do this right...
You will need
Hair dryer is all you'll need for heat.
fishing line.
Goo gone
A 50/50 mix of rubbing alcohol and water
A finger nail
Your favorite wax.
Now, take the hair dryer and heat up the emblem for about a minute to help soften the glue.
Take the fishing line an work it in a saw motion behind the emblem to cut through the glue.
After you have the emblem off, you can grab your hair dryer and heat the glue again a bit to re-soften it
Now take your fingernails and gently pick/ rub what you can off of the paint being carefull not to damage the clear coat.....using the goo gone will help disolve it.
Take the alcohol mix and neutralize the goo gone so it won't eat at your clear coat and will remove slight residue.
Wax and admire your handywork.
Old Feb 24, 2010 | 11:05 PM
speedracerg35's Avatar
you're gonna melt something or burn off the paint with a heat gun. do like ^ said and use a hair dryer. also, nothing is glued. it is double sided adhesive foam.
Old Feb 24, 2010 | 11:07 PM
4DGS's Avatar
The way I do it (heat gun this things hot as ****) if you can't hold it an inch from your hand for 30 seconds then your paint can't either. Do it in bursts and don't just leave it there for time, you'll bake your paint.
Old Feb 24, 2010 | 11:10 PM
^a heat gun an inch from your hand for 30 seconds will set your hand on fire...heat gun an inch from your hand for 5 seconds will give you a third degree burn.
Old Feb 24, 2010 | 11:15 PM
I've always used some amount of heat, but many people don't even use a hair dryer, just rip the emblem off with some fishing line and call it a day.
Old Feb 25, 2010 | 12:14 AM
lefizzet's Avatar
I just debadged my car on a hot summer day, you don't need that much heat although it just makes it a little easier. The shadow goes away in a couple of weeks so don't worry about that.
Old Feb 25, 2010 | 01:53 AM
spankey167's Avatar
I followed that video that someone posted on here about debadging. The guy used a blow dryer to heat the emblems, fishing line or floss to remove them, then used Turtle Wax - Bug and Tar remover spray on the left over adhesive, sit for 5 minutes, wipe off and use blow dryer on the adhesive for 5 minutes and you can rub it off with your finger. If it doesnt come off, add more bug and tar remver a few more times and heat.
Old Feb 25, 2010 | 11:19 AM
itsgroll's Avatar
this is want i needed to know. Thanks guys
Old Feb 25, 2010 | 12:21 PM
orion71483's Avatar
If you have a sedan, be prepared to look at 2 holes in your trunk. I forgot what years it was though.
Old Feb 25, 2010 | 01:17 PM
itsgroll's Avatar
i have a 06 coupe. I was curious if there were any holes behind the infiniti badge. But since no one spoke up im assuming thats only for teh sedans.
Old Feb 25, 2010 | 04:32 PM
Marks G's Avatar
nopee NO HOLES.. just a nice clean shaved a$$
Old Feb 25, 2010 | 04:40 PM
IrockAG35's Avatar
Ohio G Club moderator
fishing line or dental floss works best with a blowdryer..dont need any nail polish remover or googone or any sh* like that,youll eff up the clear coat..just use some wax or claybar kit to clean up..take your time. youll see some ghosting but it will fade eventually
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
hrdwirk1
Oct 2, 2015 06:34 PM
