G35 & G37, Coupes & Sedans
06 coupe 70k?
Old Apr 22, 2010 | 06:46 PM
NoToRiouzxG's Avatar
06 coupe 70k?
Hey guys I'm in the process of buying a coupe i just had a quick question. I'm looking at one g35 coupe black w/black int. Fully loaded navi,phone,Bose, Etc. All the good stuff. Well only issue I'm having is if the miles are to much?
like i said 2006 fully loaded black on black coupe with 70k miles for 17499. Its at a dealership and is one owner with the car fax..
Is there anything i should look out for? Or is that to many miles?
Thanks in advance
Old Apr 22, 2010 | 06:58 PM
Silencer_0's Avatar
That seems like a lot of miles for an '06...
Old Apr 22, 2010 | 07:02 PM
jibberjabbers's Avatar
Willing to spend 25k? I can find you a G with everything, including Rear Active Steer. Blk on Blk. navi. Everything.
1 owner. Clean ride and only 9,700 miles.
Located 15min from Disney in Anaheim.
Old Apr 22, 2010 | 09:07 PM
That sounds like a really good deal...but I was only looking to spend 15-17 thats why i was kinda aiming for a 03-05 i just came across this 06 so looked into it..Thanks though.
So thats to many miles im guessing? lol
Old Apr 22, 2010 | 09:11 PM
70k on an 06... Yes.. But as long as the dealership ran all the service/maintenance on the G.. I don't see any issue. It has 70k.. So the dealer should check the spark plugs for oil...
The G35's are prone to oil pooling on the plugs after 70k... 17k.... You can probably find a better deal. But it's hard to find the car with your exact specs....
Old Apr 22, 2010 | 09:20 PM
not hard? haha dude i been looking for so long. I want to buy from a dealership and also i want a black on black coupe 5At. between 15-17 lower then 15 will also work lol but i cant find one anywereee!
Old Apr 22, 2010 | 09:44 PM
That's what I mean.. "But it's hard" to find the one with your spec...
You don't want mine. It's a 6mt.
Old Apr 22, 2010 | 09:55 PM
Bri127mx's Avatar
my 06 coupe has 68000... my only complaint is the axle clicking... i do, however, have a 5 page summary on all the work that's been done to my car at the dealership (e.g.: new steering wheel, ash tray, cup holders, perforated inserts under the rear side windows, o-ring for the oil cooler, had sunroof bolts tightened, and more.)
if i were to buy another g, i would make sure again that it had at least a couple thousand miles left on the bumper to bumper warranty. Any problems with the car, and infiniti will fix it on their dime as long as it has "failed". all of the above were done under warranty. ****, you can even get a new seat/seat cover if the outside edge has started to rip...
whatever you buy, make sure it has a warranty. even if it is a little more expensive... it'll benefit you in the long run.
Old Apr 22, 2010 | 10:36 PM
Minheeeme's Avatar
I paid $19 with 42K. So another $1,500 gets you half the miles almost. Definitely worth it..
Old Apr 22, 2010 | 11:30 PM
Hey guys i have an update...I found a 06 with everything exc. navi..with 59K miles for 17,000...Only problem is i like the 03-05 spoilers...Is there chances if i get that someone will trade me trunks? Or were can i buy the spoiler at?
Old Apr 24, 2010 | 10:51 PM
ThePhoenix's Avatar
i just bought a 06 with 80k+ on the clock but i checked the Infiniti maintenance and it had been maintained well by Infiniti dealers (stamps in the cars book) also i did a bit of background and it came from Arizona to Seattle a couple times back and forth with the previous owner so the miles are highway miles which are better than city miles. if you have to same thing with well maintained and good miles then its still a good car, but i would talk them down on price though, my 06 i was able to talk them down to just over 12g for the car because of miles and mentioned the oil/plug issue that its a cost i will prob have to have so get that deducted etc
these days even 100k miles is ok, although i personally stay below 90k at most, as long as you keep it maintained and it has been taken care of well then a car can last till 200k easily.
also if you get to high on miles you can always get a new motor
just my 2 cents worth
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Jay 21
Aug 5, 2015 04:53 PM
RedBaronK
Jul 27, 2015 06:25 PM
