G35 & G37, Coupes & Sedans
Whats the common problem with G35 2004
Old Jun 19, 2010 | 07:25 PM
frank358fr's Avatar
Smile Whats the common problem with G35 2004
Hi guys,
Im looking to buy a G35 2004. Ive never own a G before and im new here so my questions is: Whats the common problem with these cars? Let me know everything you know about the common problems
Thanks!
Frank!
Old Jun 19, 2010 | 07:49 PM
Hotdawwgman's Avatar
fuel consumption...
excessive speeding...
addiction to modding...
constant changing of wheels...
Old Jun 19, 2010 | 08:09 PM
jibberjabbers's Avatar
* window motor going bad
* door lock mechanism going bad
* window seals going bad (the Seal on the 2003 Toyota Celica is 10x better than ours).
* 50-70k - Spark plug gasket will start to leak oil. Commonly on the #6 plug (cost 400+ to replace). As high as 1k at the dealerships.
* clutch pedal sticking
* sunroof making "popping" sounds whenever you go over a bump
* seats start to rock back and forth (rails starts to go bad).
* car will give you a hard time filling up the tank
* rear axle clicking
* compression rod/bushing start to bust (Infinti issued a revised bushing/rod).
* oil consumption on all models. More commonly on the rev-up. But some 5AT drivers have complained about this issue
The G35 has over 70 TSB's and over 8 major recalls. Latest one being the Air bags and the Radiator fan.
Old Jun 19, 2010 | 09:59 PM
HipHopPro's Avatar
^^^Sounds like I need to go get that BMW
Old Jun 19, 2010 | 10:09 PM
Or an Acura or a Lexus. I wouldn't mind getting a TL-S or the IS-250. IS-350 only comes with the paddle shifter. (boring).
Old Jun 19, 2010 | 10:40 PM
NFSP G35's Avatar
? = 2B || !2B
I wouldn't trade the Infiniti's potential problems for the BMW's
You're not likely to have ALL those. You're most likely to have problems with the radio/cd changer though (which is the same circuit board as the AC)
Do a site search for hvac problems and you'll see what I'm talking about.
Old Jun 20, 2010 | 12:33 AM
VQ Johnny's Avatar
Don't let these problems effect your judgment too much most of these are easy fixes if you have some mechanical ability, with the exception of the OC problem which is less prevalent in the non revup motors. Most of the things listed are normal wear problems that most cars will have. Infiniti/Nissan are pretty reliable cars as long as they are taken care of. Just be sure it has service records and it should be OK and if you're unsure take it to a Nissan dealer (better service techs) to be checked out.
Old Jun 20, 2010 | 02:12 AM
frank358fr's Avatar
Thanks! Is there anything else?
Old Jun 20, 2010 | 07:21 AM
LMG_35C's Avatar
2004 here - none of those problems. 75,000 miles
but I do agree with hotdawwgman.
Old Jun 20, 2010 | 08:55 AM
NFSP G35's Avatar
? = 2B || !2B
Yeah, mine's an 03 with 118,000mi and I've only had ONE problem off jj's list (seat is just now starting to rock)
But I've had ALL FOUR "problems" off hotdawwgman's list
Old Jun 20, 2010 | 09:18 AM
frank358fr's Avatar
Is there any way I can check if the cylinder #1 and #6 are leaking without removing the coil?
Old Jun 20, 2010 | 11:34 AM
gary c's Avatar
........ Had I read some of these lists I would have never bought a G35. I've had none of these issues, but you forgot one....poor quality brakes. Which can be resolved by using aftermarket pads like Hawks rather than OE which are big time junk....
Gary
Old Jun 20, 2010 | 12:17 PM
kevink's Avatar
I second the question about the oil from spark plug. Is this something that would be noticed/mentioned at service (like the 60K service)? Or something like oil dripping on garage floor?
I'm at 68500, and the only issues I've noticed is the seat rail issue, which I've had fixed twice under warranty. Still have 3 months remaining on extended warranty.
The only other "issues" I've had are battery replaced (affects pretty much all cars), front brakes (wear), tires (wear), windshield (rock), paint (parking lots, other cars run red lights).
Old Jun 20, 2010 | 03:14 PM
Only way to find out is to pull out your spark plugs.
Old Jun 20, 2010 | 03:48 PM
the_sedan's Avatar
i replaced my passenger side window motor and clutch switch. thats all. 04 coupe with 58k.
