HKS knock offs
ˆDam it is kinda off to ask that question but still a question is a question bro...
"EVEN A GENIUS ASK-ES QUESTIONS" 2pac...
IF you realllllllly had to go with a knock off go with ARK...check the vendors area
Yeah STATIK aka Hennry can hook you up for about $350 i think but it is the X02 or M2 or something along those lines that I JUST heard will rust... and Statiks uses an h pipe while Ark has an x pipe i believe...
I have the HKS "knock-off" and don't have a problem with other than the mis-aligned tips. Easy fix. Got it for $260 picked up brand new.
I've added test pipes and a Magnaflow resonated x-pipe. The knock h-pipe is a joke. It's only a 1/4" hole drilled into the piping. Almost useless. After the x-pipe, the exhaust is really reduced the sound. Quieter than before the test pipes. Real quiet when cruising on the freeway. If you live in a wet area with lots of rain and snow, chances are that it will rust.
Here's my video's of the exhaust.
Comparison of test pipes and OEM cats (no x-pipe)
With test pipes and x-pipe on the dyno
Idle rev with test pipes and x-pipe
knock-offs....why buy some cheap azz system you have to add a crossover to and it still doesn't line up correctly to save a few $$? The OE exhaust is better made and would sound good if you just add HFCs, this isn't the Honda you used to drive don't make it so!Gary
ibtl
