G35 & G37, Coupes & Sedans
Question about AWD and brakes
Old Jul 12, 2010 | 07:27 PM
iLoveMyG35x's Avatar
Brakes Question about AWD and brakes
Do i have to match brake pad/rotor brands/styles for all of my wheels or is it okay to have OEM for the front and Wagner Thermoquiet for the back?
Thanks in advance for the advice!
Old Jul 14, 2010 | 02:36 PM
OKStateG35's Avatar
I don't think it would cause any major issues, but I always replace all the pads at once. You should also turn or replace your rotors at the same time.
Old Jul 14, 2010 | 04:34 PM
marcinr's Avatar
20 Year Member
It won't cause problems, but if you put in pads/rotors with drastically different characteristics in front and back, your brake balance changes away from what the car was designed for, so you may find yourself having issues when braking in a turn (not that you should do that).
Old Jul 14, 2010 | 07:32 PM
ah, thanks for the info OKstate and marcinr. The brakes should be pretty similar, so i think i will be okay based on what you have both said. I would change them all but the dealer put new pads on the front when i bought the car last October)... so the front pads are in pretty good shape still.. the back ones are worn down..
Thanks again!
Jiggerjuice
Aug 17, 2015 08:41 AM
Srinidhi
Aug 7, 2015 03:38 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
mushu
Jul 15, 2015 03:55 PM
