G35 & G37, Coupes & Sedans
5A/T question
Old Jul 20, 2010 | 11:03 AM
  #31
Swivel's Avatar
Moderator
^^ That I don't know. You might find some very good info in threads where guys are swapping AT to MT, I know s/n Canadian is doing one right now. Also, my350z.com members tend to do crazier/more technical stuff and write about it, you could check there.
Old Jul 20, 2010 | 11:11 AM
  #32
Tollboothwilley's Avatar
Canadian is swapping from 5AT to 6MT because the 5AT that he had built burned up on him. 6MT handles boost much better.
Most people who want an automatic that is boosted don't go over 400 whp and are careful not to just "jump" into boost because of the shock to the transmission. I've seen people do LS-X swaps and if they stay auto they get the T400.
All in all, I'd say unless you plan to go boosted right away, just throw in the Transgo shift kit, change out the Final Drive and you'll have a much more fun vehicle to drive.
Old Jul 20, 2010 | 05:10 PM
  #33
Lucas's Avatar
despite the rough start, i appreciate the info and input. i may just wait on her to really **** me off then swap to a 6MT. My fear with boosting the engine is that the tranny wont hold up.
Old Jul 21, 2010 | 12:12 AM
  #34
rcdash's Avatar
The reason it burned up has nothing to do with the fact that it is a 5AT . 500 wtq going on 20k miles here with no issues.
If you want to go over 600 wtq, then you are taking a risk, but below that a 5AT will be competitive with 6MTs with up to 100 whp advantage (thanks to no drop in boost between shifts and quick shift times). Driving a 6MT with 600 whp is not for the feint of heart. A 5AT makes it easy. On a 6MT, you get much over the 700 whp range and you have to be very selective with parts to get any life out of them, so it's an expensive proposition either way in regards to the build up and ongoing maintenance if you're shooting past the 600 whp mark.
Old Jul 21, 2010 | 11:12 AM
  #35
Lucas's Avatar
that sounds a bit better to me, id hate to think that nissan built a solid engine and put a **** tranny behind it. i was getting ready to sell the car for a sec there, or reconsider the titan swap.
Old Jul 22, 2010 | 11:00 AM
  #36
rcdash's Avatar
Titans use the same transmission. You just need to keep it cool as you put more power through it. If we had a way to increase line pressure through reprogramming, we wouldn't need the mechanical valve body upgrade either. UpRev has been able to reprogram some TCMs (but I think they only do it on a one off basis).
Old Jul 23, 2010 | 03:10 PM
  #38
Lucas's Avatar
Originally Posted by HomieG35
This topic has jumped around so much... are you wanting to upgrade the car or not? Or are you just wanting another gear while keeping the car pretty stock?
Again... getting a different rearend (like 4.0 gears) with a higher final drive seems to be what you're looking for, no? It will also be cheaper to get a different gear for the rear end changed than it would to be add another gear to the 5AT - or swap another trans in.
Unfortunately, these new Nissans are not like the old domestics. Parts are NOT so easily interchanged - not to mention the ECU is going to freak when it has another gear to work with... don't forget there are computers for the 5AT that control shifts in ever aspect and they also communicate with another computers around the car like the main ECU and traction control system, etc... 5AT's are not even compatible between some years...
i am aware of the electrical venues i may have to take.....i am going to build the engine, thats a definite, all this started with me wanting to leave the car an auto for my wife's sake, but upgrade to a 6 04 7 sp auto and changing the final drive. 4.0 gears would be too high for me, this is a daily for now, until i can get the beater truck im looking for. i commute about 150 miles round trip every day for work, and its all interstate.
Old Jul 26, 2010 | 01:56 PM
  #40
Lone Wolf's Avatar
I'm selling my supercharger if you are interested It's in the market place!
You gonna get some twins..
Old Jul 26, 2010 | 06:25 PM
  #41
impreza619's Avatar
the arguments in this thread remind me of this .... Replace Ipod4 with I WANT A 6 Speed AT. Do you have a 6 Speed AT! ^^
i feel the OP is just trolling along....
Old Jul 29, 2010 | 10:51 AM
  #42
HavokGT's Avatar
buy yourself a MT. buy her a cheap AT. and call it a day. who matters more, you or your wife... >_> imo i always look out for numbero uno... which is my G <3
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
