G35 & G37, Coupes & Sedans
Should I Get a Optima Red Top or Yellow Top Battery?
Old Aug 27, 2010 | 10:38 PM
O HELLA OEM's Avatar
thanks everyone. if NTB has the optima in stock ill buy the yellow top if not then ill just settle for any battery lol.
Old Aug 27, 2010 | 10:43 PM
whoozyadaddy7's Avatar
lol, its good to know someone else handles the tough decisions in life the same way as me! i ended up settling for a duralast simply because I needed a stinkin battery and that was all that they offered me.
Old Aug 27, 2010 | 10:58 PM
Neu Era's Avatar
Still have my OEM
Old Aug 27, 2010 | 11:00 PM
SDGenius's Avatar
go to a nissan dealership and replace ur battery, hella cheaper.
Old Aug 28, 2010 | 03:12 AM
Z-guy's Avatar
My Yellow Top dies all the time! I think I have a parasitic power loss somewhere.
Old Aug 28, 2010 | 03:53 AM
mjholla19's Avatar
Well you can go to autozone they check batteries and alternators for free i know worked there for a year and a half aftermarket batteries usaully last 1-3 years depending on which one you buy cca and quality oem last 5-6 years optimum battery 2-4 plus you get 3 years warranty i would never buy another battery other optimum
They say the yellow is better for sound systems and truck but i had the red top in my legend coupe for 3 yrs no problems the car had 2 12 pumping 1200 watts and 1000 watt amp worked great
Old Aug 28, 2010 | 03:55 AM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
yellow top D35 ftmfw.
Old Aug 28, 2010 | 10:47 AM
I went yo ntb this morning and it was indeed my oem battery going dead so I got a new battery for $135 installed.
But while going to work I put my drivers side window down and tried to put the window up and it won't go up!!! Awesome
Old Aug 28, 2010 | 11:18 AM
redwillow's Avatar
20 Year Member
i bought one of the optima batteries for my old g35 and it was deader than fried chicken right out of the box. The oem batteries are pretty good, and the dealership swapped it out for free even though i was out of warranty. I'll never buy another optima battery again, just seems like a gimmick.
Old Aug 28, 2010 | 11:23 AM
citymunky's Avatar
Optima's are no gimmick, even Aircraft Support Equipment I use everyday at work have Red-tops.
I got a free used Yellow top because it was "dead". I been using in ever since 2006 with my JL audio 500W amp and two JL 10W3v3 subs since installed it, no problems yet.
Old Aug 28, 2010 | 11:42 AM
alfhasg35's Avatar
Yellow top.?? Got one a few yrs ago. It works like the oem.. It starts the car and plays my system. Haven't had any issues..
Old Aug 28, 2010 | 11:46 AM
blazeplacid's Avatar
yellow top is a deep cycle battery as well as a starting battery
the reason its good for audio and accessories is that the battery is made to be drained and then refilled numerous times. It hold the charge for a very long time and has no issues when starting.
The yellow top is perfect if you play your set up with the car OFF for long periods of time.
Redtop is a starting battery, its made to be stored for long times without having any issues. Its made to have a high CCA in all temps. The redtop also has a large storage capacity and will work for audio setups also.
ive used both and both a re great batteries. The yellow top is more expensive because its both a deep cycle and a starting battery.
If you are running a simple amp and head unit combo any decent battery will work
Optima is the bose of batteries IMO.
Kinetik is the way to go if you need huge reserve times or a big starting battery
I myself run a battery from Sams. It was $80 and has a 3 year replace / 84 month prorate. Its been ruining fine for a year and I run roughly 1600rms in my car daily.
Optima is 1 year on reds and I think 90 day on yellow tops
Old Aug 28, 2010 | 01:24 PM
redwillow's Avatar
20 Year Member
you'd think they would test them before they send them out to people as brand new......When I asked them why i was sent a "new" battery that measured 8 volts, they said they don't have the time to measure every battery before they send it out....nice quality control.
Optima never offered to re-imburse me for the time to install & remove the dead new battery they sent me, and I actually had to dispute my C/C charge for it just to get my money back after it was returned to them.
Old Aug 28, 2010 | 03:40 PM
mjholla19's Avatar
Optima batteries are the best batteries i left my lights on all night came nack oit in the am and it started that would have never happen with any other battery the oem batteries are good but but dont hold up to a strong system i would never buy another battery other than optima
Old Aug 28, 2010 | 04:21 PM
  #30
Project's Avatar
Optima ftw. Great batteries. Check out summitracing they usually have them in stock. Also local places jack up the price. I would look online and it will be delivered to your doorstep.
