G35 & G37, Coupes & Sedans
clutch squeek!!
Old Aug 31, 2010 | 06:59 PM
dcryan90's Avatar
clutch squeek!!
ok so on my 350z when i push in the clutch pedal all the way and get a kinda squeek every time is this normal or is something about to go or possibly is some kind of oil needed?
Old Aug 31, 2010 | 09:10 PM
VQ Johnny's Avatar
Is it the pedal or outside? If its the pedal this may help.
https://g35driver.com/forums/faq-diy...pedal-fix.html
If its outside you need to go underneath the car and push the ruber boot back from the withdraw lever and spray a LITTLE lube on the contact points. There's a diy somewhere I just can't find it.
Old Aug 31, 2010 | 10:26 PM
dcryan90's Avatar
thanks so much and im pretty sure its outside from the actual part not the clutch pedal itself i was just trying to demonstrate when it happens.
Old Sep 1, 2010 | 02:41 PM
saywat?'s Avatar
interesting i thought the squeak came from the spring behind the pedal. mines comes and goes
Old Sep 2, 2010 | 09:37 AM
dcryan90's Avatar
yea i know of the clutch pedal squeek but thats a different issue this is more along the lines of what johnnyd6404 said ill post when i figure out the problem i havent been able to get underneath the car due to bad weather
Old Sep 2, 2010 | 10:26 AM
gary c's Avatar
Originally Posted by johnnyd6404
Is it the pedal or outside? If its the pedal this may help.https://g35driver.com/forums/faq-diy...pedal-fix.html
If this....^....doesn't work there's a possibility the noise you're hearing is a throw-out bearing that's gone dry/worn out and will need to be replaced before it freezes up completely....
Gary
Old Sep 2, 2010 | 11:53 AM
dcryan90's Avatar
yea that's why I'mdriving the g for now till it gets fixed
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
bigmike
Sep 17, 2015 01:58 PM
jbmw002
Sep 10, 2015 12:54 AM
