G35 & G37, Coupes & Sedans
Clanking noise when braking.
Old Oct 15, 2011 | 04:32 PM
N80's Avatar
N80
Originally Posted by djamps
It's your axles. I've seen them make all kinds of noises under any condition (even braking).
You must not have read what I've said so far. It is not the axles. It only occurs under braking and it went away when the shims were lubed.
EBC packages their pads with an anti-squeak pad that goes between the shims and the brake pad. On the rear, the pads have some little stubs that need to be ground down in order to fit the anti-squeak pad. I did not bother with it but I'd bet they would solve this problem too. I'll probably put them on next chance I get.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
