G35 & G37, Coupes & Sedans
Engine bay trim panels missing.
Old Oct 21, 2010 | 01:20 PM
SECG35's Avatar
Old Oct 21, 2010 | 01:23 PM
SECG35's Avatar
I got it figured out with some measurements and tin snips. I just need to get some correct clips now. The engine bay looks so much better and complete now.
Old Oct 21, 2010 | 04:28 PM
N80's Avatar
N80
Pictures please! Are the clips you're talking about the same as the ones on the battery side? Are there holes on the brake side for them?
Old Oct 21, 2010 | 06:20 PM
BlkCoupe's Avatar
Yes, they are the same clips. You can purchase a bag of 8 from Riverside Infiniti. If you are in a hurry strangely enough LOWES carries some automotive fasteners in their screw, nut, bolt, nail aisle. They are where they have the drawers full of speciality fasterners labeled Automotive. O'Reilly also sells them. N80 buy the already trimmed one its like $10.00 more and like I said 15 min. with complete instructions.
Old Oct 21, 2010 | 06:48 PM
gary c's Avatar
Fitting that cover on the drivers side is so easy, set it where it's supposed to go and trim around the edges until it fits. A blind monkey with a pocket knife could do this, why pay $10 more for someone to do it for ya? Push clips are available from Nissan or Infiniti, never hurts to have a few extra cause they break.
Gary
Old Oct 22, 2010 | 10:56 AM
BlkCoupe's Avatar
I don't own a monkey let alone a blind monkey. Everybody knows you shouldn't let monkeys play with sharp objects. By the OPs posts the already fitted sounded like a better choice.
Old Oct 22, 2010 | 11:02 AM
N80's Avatar
N80
I'm actually the OP. I was just curious about why the panel wasn't there. I'm not too interested in putting one in. If I was I could go either way with trimmed vs not trimmed. A lot of us can do this sort of thing but a lot of us don't have the time to do it, in which case the $10 would probably be worth it. But $30 for the part, $10 more for the trimmed and $8 for clips and you're pushing $50. I'm going to save my money and just not look under there anymore.
Old Oct 22, 2010 | 11:31 AM
BlkCoupe's Avatar
Sorry, I didn't mean to imply that you couldn't do it. Just saying that the already fitted comes with the clips and the metal bracket that is required so you have everything you need from the get go. Most importantly it comes with instructions with photos that I found very helpful. Wouldn't help the blind monkey much though!!
Old Oct 22, 2010 | 04:41 PM
jibberjabbers's Avatar
sad thing is, you have to pull the cover out to fill the clutch fluid. as the pop out cover is too small.
Old Oct 22, 2010 | 05:02 PM
BlkCoupe's Avatar
Your's must not fit like mine. Not only can you add fluid by just removing the battery cover door. But, I have a Mityvac Clamp-on Auto-refill kit with a forty ounce reservoir for bleeding and refilling the brake lines which will also fit without removing the entire cover.
Old Oct 22, 2010 | 05:07 PM
N80's Avatar
N80
Hey BlkCoupe, this is hijakcing a bit but since I'm the OP....how do you like the auto refill kit? I'm hoping to start tracking mine soon and it would be nice to have an easy way to bleed and change fluids. How much does it cost? How hard to install? Going to be getting new pads, maybe stainless hoses and front rotors too so this owuld be the time to do it I suppose.
Old Oct 22, 2010 | 05:08 PM
I was referring to the clutch fluid, not brake.
The clutch fluid reservoir is covered by the outer panel, it's basically tucked in and no way you can get to it w/o removing the entire panel.
Old Oct 22, 2010 | 05:46 PM
BlkCoupe's Avatar
Sorry jibber I have an auto. N80 I have the Mityvac Model MVA6832. Prices vary widely from around $35 up. Gotta watch the shipping though. The $35 dollar one is on Amazon but shippings $12. It works great but is not a necessity if you keep your eye on the reservior. If your going to be changing brake fluid alot (i.e. tracking your car) it would be worth it.
Old Oct 22, 2010 | 08:13 PM
4DGS's Avatar
Well it's not intended to be there for a reason lol
On the Z you've still gotta pull the **** up to get to the clutch.
Old Nov 1, 2010 | 12:57 PM
  #30
03IPG's Avatar
Just installed the JDM Battery Cover in my car this weekend. I bought the "pre-cut" one and it was a pretty simple install.
Took a little fighting with the "weather strips" to get everything in, but took about 15 min in total.
For $10 more I would get the pre-cut one because it already comes with 5 clips ($5.50 for 5 clips at the dealership by my house) and you don't have to worry about cutting it yourself.
Looks so much cleaner under the hood now.
zoop425
Mar 29, 2016 05:51 PM
pigpen infiniti
Aug 16, 2015 09:07 PM
