G35 & G37, Coupes & Sedans
Another SLIP, VDC, ABS thread-please help!
Old Apr 18, 2011 | 06:04 AM
Blue Dream's Avatar
I drove ttrank's car solo
Talk about back from the dead^^^^
Good to see you back in action Bill.
Old May 11, 2011 | 09:32 PM
512G's Avatar
I have this same problem and I tried putting my friends wheels on which matched up with the size of the rears(my fronts are 35 and my rears are 40) and the abs stopped acting up, but when I put my stock wheels back on the problem came back what pisses me off about this is that the tires were the car when I bought it and worked perfectly fine until I put aftermarket 19s on and then switched back!! Ugh someone have a solution please!!
Old May 11, 2011 | 10:02 PM
mjd240's Avatar
Maybe a drive thru the rain to clean the sensors will fix the problem. Worked for me??!?
Old May 17, 2011 | 02:25 PM
ensbrian's Avatar
There are a lot of reasons for the light as I was told by a shop. after using his $7000 scanner he told me there was a speed sensor problem in 3 out of my 4 wheels. I looked up did the research but there wasn't much about it out there, except for one that said to keep it clean. Being a do-it-yourself mechanic, I took off all the tires found where the sensors were, and to my suprise, i was stuffed with brake dust and it was moist, got a rag and cleaned it from the small hole where the sensor went in. After cleaning put it back together and to my surprise....The Lights Went Out! Hope this helps G'sters!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
markbilo
Sep 30, 2015 01:33 AM
vamarris
Sep 26, 2015 12:56 PM
