G35 & G37, Coupes & Sedans
G35 has very low clearance, but I solved my parking problem
Old Dec 21, 2010 | 10:13 AM
Tollboothwilley's Avatar
stock size is 215/55/17.
245/35/19 will effectively lower him about 1/4"
225/55/17 will raise you 1/5"
245/40/19 will raise you 1/5"
Getting a slightly larger tire is not going to effect you.
Old Dec 21, 2010 | 10:40 AM
G2FLIP4's Avatar
everything
Just say no to balloon tires!!!
Old Dec 21, 2010 | 11:03 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
According to my calculations a 245/40/19 tire is 1.2" taller than a 215/50/17. However a 245/35/19 is only .3" taller so Massios is correct.
Oem coupe 17's come with 225/50 235/50. The 225/40/19 front is the same diameter as the 225/50/17. The 245/40/19
Rear is less than .25"
Taller than the 235/50/17. So the back of the car would raise 1/8", very negligible.
Old Dec 21, 2010 | 11:34 AM
gary c's Avatar
Great idea adding those lifts to your driveway, glad it's working for you. I've seen those kinda curbs in other states too, that crazy....but they have a purpose and obviously work. There are areas here in SoCal where they're needed from the dreaded storm runoff.
Gary
Old Dec 21, 2010 | 09:30 PM
impulse_x's Avatar
It didn't work when you drove through on an angle...?
chinee
Jun 10, 2024 07:48 PM
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
Ashton35
Jul 17, 2015 10:11 AM
