G35 & G37, Coupes & Sedans
How fast is that new IPL G?
Old May 8, 2012 | 05:03 AM
EvansIPL's Avatar
I just bought a G37 IPL and I will probably be taking it to the track on May 22nd. Im heading to Fomoso raceway in Bakersfield CA. Its about 635ft in elevation and it will probably be in the low 80s to high 70s since it will be evening racing. I will keep you all posted on what times I run. Ill also be running with aftermarket intakes most likely by then
Old May 8, 2012 | 05:05 AM
EvansIPL's Avatar
hey guys, new to the forum.... I just bought a G37 IPL and I will probably be taking it to the track on May 22nd. Im heading to Fomoso raceway in Bakersfield CA. Its about 635ft in elevation and it will probably be in the low 80s to high 70s since it will be evening racing. I will keep you all posted on what times I run. Ill also be running with aftermarket intakes most likely by then
Old May 8, 2012 | 10:57 AM
ConradoR's Avatar
Double post causing a 100% post count increase.com ftw
Old May 8, 2012 | 12:28 PM
BlkCoupe's Avatar
The problem with putting a V8 in the IPL is price. The Mercedes C Coupe which is comparable to a G37 bases at 42,370 but when you go to the C63 AMG Coupe your looking at a base price of 61,430. At that price point you get a 6.3L V8 producing 451 hp. In order to get more horespower out of the IPL whether by Turbo or V8 the price is going to have to go up probably high 50,000.
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
magnetism80
Jan 27, 2016 12:57 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
