G35 & G37, Coupes & Sedans
Tire pressure monitor?
Old Jan 4, 2011 | 04:12 PM
super6's Avatar
do the new Gs or older ones even have TPMS? if so how do i get ti it from the menu?
thanx.
Old Jan 4, 2011 | 09:14 PM
dave's Avatar
All coupes have TPMS (I don't know about sedans). At least on the older ones, there isn't a menu for it. It just beeps and lights up when a tire is low.
Old Jan 4, 2011 | 09:18 PM
super6's Avatar
ohh, so there is no display where it shows the pressure in each wheel?
Old Jan 4, 2011 | 09:54 PM
jonesmeister11's Avatar
i have an 03 coupe and when I got new rims the bead wasnt sealed right. Got out of school and had a flat, with no light on the dash or a beep.
Old Jan 4, 2011 | 10:00 PM
4DGS's Avatar
^ either tire shop didn't mount your TPMS or you didn't calibrate them.
No, they don't show PSI in the tires, they only notify you when the tire slips under 32psi.
Only cars I have seen that have an accurate read out of pressure are the new Mercedes.
There is a kit you can buy that has valve caps that are transmitters and a receiver that goes inside the car and will give you a read out. They can be anywhere from $25 to $200.
Old Jan 4, 2011 | 11:12 PM
sillyoldtayo's Avatar
x2 our TPMS only tells you when you have low tire pressure. Mine came on when I was 3psi low just like 4DGS said.
Old Jan 5, 2011 | 02:55 PM
saywat?'s Avatar
my 03 coupe doesnt have tpms
Old Jan 5, 2011 | 04:53 PM
gary c's Avatar
I've had my TPS in and out of 3 different sets of wheels and they still work without fail. When my tire pressure drops below 28 lbs it shows on my dash and makes a screeching noise in the beginning. In our low profile tires you can't tell if you have forty lbs or fourteen in them by the way they look...
Gary
Old Jan 5, 2011 | 04:55 PM
bluedevils95's Avatar
You can't unless you have after market ones.
Old Jan 5, 2011 | 08:31 PM
dave's Avatar
It looks like the TPMS wasn't added until 2004
Danielek
Sep 20, 2015 12:08 PM
JoeMac
Aug 20, 2015 10:17 AM
