G35 & G37, Coupes & Sedans
They forgot about us, 05-06 Gen G35 SEDAN?
Old Jan 7, 2011 | 04:40 PM
Cog_86's Avatar
Cant find anything for g35 sedan 05-06 gen, asthetic wise !
Esp eyelids, projector lamps (not talking about retro fits)
Old Jan 7, 2011 | 05:24 PM
CandlestickPark's Avatar
ill Sedan
It is true that there is more aftermarket support for the 03-04 Sedans vs the 05-06 Sedans. That doesn't mean you can't put together a nice exterior, you may just have to get creative and do a few things custom. What specifically are you looking for?
Not aware of any eyelids made for the 05-06. What do you mean by projector "lamps"?
Old Jan 7, 2011 | 05:54 PM
Cog_86's Avatar
Projector Lenses on headlamps..
jyust like the 03-04 sedans.. the 05-06 sedans dont have that !
Old Jan 14, 2011 | 07:25 PM
G35MTK's Avatar
You can make your own eyelids. Buy some vinyl and cut them out. Cheap and easy mod for $20. Like Marcus said, you just have to get creative.
For the front check out the KuRookie front bumper and also check out the NisRookie sides. PM MartyG35
If you want to do something with the rear you need to swap your bumper for an 03-04 and then you can do the replica nismo lip.
It might be a bit of a pain but good looking modded g sedans are a rarity on the roads and really turn heads. Well worth the time and effort.
Old Jan 14, 2011 | 08:29 PM
4DGS's Avatar
03/04 are just getting them now, suck it up for two years.
Old Jan 15, 2011 | 12:11 AM
Cog_86's Avatar
True!
I havent seen any pics of vinyl custom eyelids!
Im going to probably do it... have to paint it graphite too just like my cars color.
Old Jan 15, 2011 | 03:02 PM
acr's Avatar
acr
05/06 sedans do have less aftermarket support, but we are at an advantage since the OEM bumper is much better looking than the 03/04, plus our lower sills came painted from the factory. The retrofit source can also supply you with everything you need to retrofit some projectors in your OEM lights as well.
Old Jan 15, 2011 | 10:56 PM
G35MTK's Avatar
True!
Hate to keep whoring out my car, but here are my eyelids.
been on for almost 3 years no problems! Back when I was rocking the oem lip!
Old Jan 16, 2011 | 01:19 AM
Cog_86's Avatar
OUF SEXY!!
Did u manually cut them or you used a template?
I have to buy paint for my vinyls tho my cars graphite color!
Old Jan 16, 2011 | 01:59 AM
G35MTK's Avatar
OUF SEXY!!
I laid the vinyl on first. Then I marked the shape I wanted for the eyelid. I cut out the eyelid and used the backing as a template for the other side. You should shop around and see if you can get some vinyl that matches.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
raeyang
Jul 25, 2015 11:25 AM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
