G35 & G37, Coupes & Sedans
Buy all new rims or replace 9.5 with 9?
Old Jan 20, 2011 | 08:35 PM
sistom's Avatar
I have a 2003 G35 sedan.
For rims I have 19x8.5 in the front and 19x9.5 in the rear.
I've had constant issues with the right rear rim with a perfectly good tire on it. It keeps going flat. It started with a bend in the rim, I had it straightened out but in the process they cracked the damn rim. So they welded the crack. Well, since then a crack has appeared in the weld as well.
I'm tired of messing with this rim and I just want to buy a new one.
Problem is, I can't find a 9.5 anywhere. All I can find are 9.0...
Can I replace a 9.5 with a 9.0?
Also, for tires I have:
Nankang NS-II Tires
Front: 225/40-19 40R19
Rear: 245/40-19 40R19
Will the 245s fit on a 9.0?
Any help is greatly appreciated!
Thanks.
Old Jan 20, 2011 | 09:29 PM
RogerG35's Avatar
Yes you can replace a 9.5 with a 9.0, but I suggest you change out the other side as well. And yes, a 245 will fit on a 9.0 as long as its 19"
Old Jan 20, 2011 | 10:08 PM
gary c's Avatar
Can I replace a 9.5 with a 9.0? Also, for tires I have: Nankang NS-II Tires
Front: 225/40-19 40R19 Rear: 245/40-19 40R19
Will the 245s fit on a 9.0? Any help is greatly appreciated! Thanks.
You gave us some information but are we to assume you're refering to OE 19" coupe rims? If so, find a Nissan/Infiniti wrecking yard in your area and buy the correct rim....whatever it might be! You could run the 245s front and back on 9" rims, I was never satisfied with smaller 225s in front.
Gary
Old Jan 20, 2011 | 10:12 PM
sistom's Avatar
Gary
Ack! Sorry. lol
19" Konig Trouble
Old Jan 20, 2011 | 10:18 PM
gary c's Avatar
Ack! Sorry. lol 19" Konig Trouble
Here's a thought, GOOGLE Konig and see if anyone has the wheel your trying to replace in the 19.5" size. Maybe you can contact them directly.... worth a try!
Gary
vitamin.v
Nov 7, 2019 06:10 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
BlackGee35
Jul 31, 2015 11:04 AM
nervseele
Texas
Jul 29, 2015 08:49 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
