G35 & G37, Coupes & Sedans
Soooo I get about 8 mpg in my 03 coupe...
Old Jan 23, 2011 | 05:19 PM
Enigmatic42's Avatar
Originally Posted by kricci11
not sure i really understand...
if in 6th and you floor it - the car will bog down and take a little while to get to speed... if I'm in 6th and thinking about flooring it, i will downshift - then when i get to my speed of choice, i move back into 6th and cruise
The higher the RPM's the more gas you are consuming/burning... basically the engine is working harder.
Let me state it more clearly, sorry. Just had two jagerbombs. Anyways, so, is the amount of gas you are currently using based more on the RPMs, or based on how far the pedal is depressed?
Old Jan 23, 2011 | 05:23 PM
GeezNuts's Avatar
LOL! Nice
I am sure someone much smarter than me could chime in, but my theory is that they higher the RPM's the more gas.
So if you are doing 40 in 3rd and 40 in 5th and you want to get to 55. You floor it in both scenarios, your RPM's will go higher more quickly in 3rd than in 5th. Therefor you'd be using more gas in 3rd gear vs 5th to get to the same speed. 3rd would obviously get you there faster though...
Old Jan 23, 2011 | 05:30 PM
LOL! Nice
I was almost positive the amount you depress the pedal was related directly to the amount of gas used, just makes logical sense, but maybe you're right. I'll wait for others to chime in and see what happens.
Old Jan 23, 2011 | 05:33 PM
GeezNuts's Avatar
I would agree with that theory in an automatic - not sure about a standard transmission though... I'm curious now as well.
pwestbball11's Avatar
At 40 i am also in sixth. Its true the engine is boggy and you dont get any acceleration but thats what the cluth and second gear is for I think 8mpg is about right for driving around in third gear going 40mph
Old Jan 23, 2011 | 05:41 PM
Project's Avatar
Theres definately a non driving issue. When is the last time you cleaned your injectors, switched plugs, air filter etc. ? I tend to run high rpms and only get around 20 in town.
The thing with bog is you dont want to be under revved where its got no power therefore burning gas because the engine is actually working harder to keep up the speed. For cruising 2500 is the optimal range to be around. Also on the other side you dont want to be revving the hell out of the car until 4500 or more since it will be eating gas trying to spin the engine up that much.
Old Jan 23, 2011 | 05:48 PM
mistasleepi's Avatar
8 mpg that's normal i only get 10 i cleaned my injectors plugs filter etc and still get 10 the most 11 on city
Old Jan 23, 2011 | 06:05 PM
I find it hard to believe thats normal, unless the car is extremely old, and i feel like 7 years isnt old enough to reduce the efficiency by half of the official values
Old Jan 23, 2011 | 06:12 PM
walshtj's Avatar
Dont judge it based on the needle location as there will always be a ton of error associated with that broad of a guess. Calculate it by taking the miles driven divided by the number of gallons the pump tells you, you put in.. And with your driving habits it sounds like you are just misreading the horribly accurate gas gauge. Should be closer to atleast 16 mpg.
Old Jan 23, 2011 | 06:13 PM
The X Factor's Avatar
Originally Posted by marcinr
You're not getting 8mpg, the fuel gauge isn't precise enough to make these measurements. Fill up to full, zero out the trip meter, and next time you fill up to full, divide miles by gallons.
This.
Halfway on the fuel gauge is not equal to half your fuel tank. The light comes on near empty when you have 4-5 gallons left in a 20 gallon tank. I'm not sure about you, but my light comes on well under the 1/4 mark.
Old Jan 23, 2011 | 09:37 PM
I'll definitely get back to you guys in a few days when I fill up, should be interesting.
Old Jan 24, 2011 | 02:07 PM
cmesidewayz's Avatar
instead of looking at the needle... see how reliable your gas gauge is cause some G's are known to have weird problems... next time you fill up check how many gallons you put in
Old Jan 24, 2011 | 02:13 PM
but if you think about it your engine is constantly checking for the right air to fuel mixture so unless your rpms are up and taking in more air, you wont use more gas when at full throttle. if your amount of throttle was directly related to the amount of gas it would be similar to a carburated engine ya know?
Old Jan 24, 2011 | 02:35 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
The manual says that you can cruise in 6th at 35mph. I do it all the time.
Old Jan 24, 2011 | 03:52 PM
  #30
Tricky-Ricky's Avatar
40MPH in 5th talk about granny shifting (to quote a corny line)
Sounds to me like a lambda problem, take it to a mechanic with Nissan diagnostics and have it checked.
