G35 & G37, Coupes & Sedans
Took my 05 Coupe for an oil change
Old Mar 9, 2011 | 02:42 PM
The-Dream's Avatar
So I dropped my car off at Frisby's for an oil change and now they said that the oil light is it. The light wasn't on prior to the oil change. What should I do? They just called and I still didn't pick the car up yet.
Old Mar 9, 2011 | 02:56 PM
saywat?'s Avatar
first off u get minus 5 g35driver points for not changing ur own oil. and second did those guys put enough oil ?
Old Mar 9, 2011 | 03:55 PM
sykoenigma's Avatar
^ time = money
some people don't have enough of one or the other..
Old Mar 9, 2011 | 04:37 PM
The-Dream's Avatar
So there's enough oil and the light is still on. They ran the ODBII and no codes came up either. Could it be the dash somehow?
Old Mar 10, 2011 | 09:44 PM
gary c's Avatar
I would want to know why this light is on since it wasn't on when you took it in for the oil change. Take it to the dealership but just ask about the light....why's this on?
Gary
Old Mar 10, 2011 | 10:17 PM
NuttinButtaG's Avatar
^^ +1
Old Mar 10, 2011 | 10:20 PM
KSWAY's Avatar
You sure they're not talking about the maintenance light?
Old Mar 11, 2011 | 10:16 AM
adamls2's Avatar
dealership checkage time
Old Mar 11, 2011 | 11:38 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Not enough time to change oil?
Seriously?
Drive up ramps: 30 sec.
Remove drain bolt: 30 sec.
Time to drain: 60 sec.
Remove filter: 15 sec.
Replace filter: 15 sec.
Refill: 3-5min.
Can you really drive to a oil change place in less time than that?
Old Mar 11, 2011 | 11:40 AM
rasetsu's Avatar
Originally Posted by sykoenigma
^ time = money
Unfortunately it looks like it's going to take OP a lot more time to get this resolved instead of just the 30 minutes max it would have taken to DIY oil change.
Old Mar 11, 2011 | 11:44 AM
rasetsu's Avatar
Replaced mine with a Fumoto valve. 2 seconds to open up, 1 second to close, and zero mess.
Some people just don't like the thought of getting dirty. To each their own, but for me, the little time it takes to DIY is well worth it for me to get under the car and take a look to make sure everything is in order and to avoid hassles such as the one OP is now experiencing.
Old Mar 13, 2011 | 08:07 PM
Sunsetrider's Avatar
Thanks for the heads up on the Fumoto valve. I will get one.
I do the oil on my MC but I can't fit under the car. I would like to know how you DIYers get the car up and level for the oil change. I have to work out in the dirt driveway (country life, gotta love it). No nice clean well-lit 2-car garage with a nice level concrete floor . . .
Old Mar 13, 2011 | 09:05 PM
jibberjabbers's Avatar
Seriously?
Refill: 3-5min.
7-9 minute for an oil change?
When I changed my own oil, it took me at least an hour.
Removing the 15+ undercover bolts takes the most time since I do not have the correct power tools.
Also driving up the ramp in a manual takes some time. Need to be really careful.
Add the extra time needed for other hiccups. Bolt too tight, cleaning surrounding area, etc etc.
Also, I let the oil drain out for at least 5 minutes or until there are barely any drops.
Old Mar 13, 2011 | 11:24 PM
Siaon's Avatar
Biggest pain in the ***.
