G35 & G37, Coupes & Sedans
Squeak sound from plastic around shifter...
Old Mar 14, 2011 | 11:23 PM
lpchristilaw's Avatar
Question Squeak sound from plastic around shifter...
Anyone have a solution for a rattle around the shifter of my 2005 g35? The piece around the shifter squeaks against the center pillar of the car. I have put arrows showing the contact points that I believe are squeaking. any creative ideas? ThanksSqueak sound from plastic around shifter...-g35shiftlever.jpg
Old Mar 14, 2011 | 11:29 PM
WhosRich's Avatar
I got the same problem on my 04. Its frustrating as hell..
Old Mar 15, 2011 | 12:44 AM
junon's Avatar
pop it up with a spatula, tighten down the screws holding the shifter assembly together, then pop it back in. the problem will resurface eventually, just rinse and repeat. I need to retorque mine, planning to use a little bit of loctite to see if it offers a more permanent remedy
Old Mar 21, 2011 | 09:25 PM
pop it with a spatula? do you have pictures of where the screws are or where it is you put the spatula to pop the plastic off?
Old Mar 21, 2011 | 09:33 PM
thescreensavers's Avatar
Mr.202?
its most likely from the plate underneath, but if it is that part, it comes off easy.
Old Mar 21, 2011 | 10:20 PM
is the plate underneath the silver part under the other silver part?
Old Mar 22, 2011 | 02:05 AM
junon's Avatar
The silver part around the boot with the gear selector marks. Just slide a spatula under it, and gently separate until it pops
Old Mar 22, 2011 | 06:02 PM
for the life of me I cannot get the entire thing to pop off, only the passenger side....
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
