G35 & G37, Coupes & Sedans
Trunk getting water in it...
Old Apr 7, 2011 | 08:41 PM
HavokGT's Avatar
Trunk is getting water in... I dont believe its the seal... Im going to replace it this weekend... but i took off the tail lights... caulked all seems where the sheet metal meets as much as I could... took of weather stripping and there was two places where the lip that the seal sat on, that had a quarter inch gap... so i took pliers and closed the gap, caulked the hell out of it, then caulked the seal before i put it back on...
still water..
any one else have this problem?
Old Apr 7, 2011 | 10:04 PM
gary c's Avatar
Get inside the trunk and have someone go around the whole area with a bright flashlight. It's also possible the rear window seal might be leaking.... These are never easy to find!
Gary
Old Apr 7, 2011 | 10:07 PM
Eric@TCGMiami's Avatar
check the emergency pull wire....
there is a small clip 1 inch away from the seal.. when it gets loose it blocks the seal from doing its job.
I had this problem.
Old Apr 8, 2011 | 03:07 AM
HavokGT's Avatar
Only issue is I see the water rolling down the wall furthers away from the front of the car... like right when you pop the trunk and look down, the wall closest to you. I stripped the trunk.. its rollin from top of trunk it seems..
g.spot
May 9, 2016 10:54 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35xdriver04
Nov 7, 2015 08:31 PM
