G35 & G37, Coupes & Sedans
05 G35 Coupe stock Bose 6 disc changer died..help with aftermarket options
Old Apr 13, 2011 | 10:42 AM
TenaxG35's Avatar
I have a 2005 G35 Coupe
What aftermarket solutions can I get that will allow me to keep the factory installed OEM Sat Navigation and climate controls. I would like to have a ipod adapter as well. Doesn't need to be fancy, single disc is fine but need to have ipod adapter and ability to still use Navigation and Climate controls.
Tried Crutchfield and they don't have a solution that will allow for the stock nav to still work (you will no longer be able to have the voice guidance function) and they dont have an adapter to keep stock OEM climate controls.
Old Apr 13, 2011 | 12:22 PM
The-Dream's Avatar
You have to get the JDM kit and trim it.
Old Apr 16, 2011 | 07:47 PM
foxx_good's Avatar
Might want to try on the audio subforum
https://g35driver.com/forums/audio-v...-jdm-trim.html
That thread has the info, bottom line is IF you can find find the nav trim its going to cost your a fortune. Best bet is the modify the jdm double din for the non nav you can find much easier
Old Apr 16, 2011 | 08:43 PM
Zioxx's Avatar
Stuck on the same boat as you
My oem bose for my 06 coupe just died on me. First it would lagg 2 read disc and now it just skips through all 6 disk as if they can't be read.
TWASkyliner
Feb 8, 2020 08:00 PM
bTanz
Oct 15, 2015 02:31 PM
Blakelyg35
Aug 15, 2015 12:12 PM
Thunderaan
Jul 22, 2015 07:40 PM
vstypicals
Jul 20, 2015 10:55 PM
