G35 & G37, Coupes & Sedans
Fuse questions
Old May 16, 2011 | 06:52 PM
Beebo's Avatar
Fuse questions
Where are the fog light and headlight fuses located on an 05 G coupe?
where are they located on a 03.5 G Sedan?
i thought they were behind the battery but i cant find them... are they labeled something else?
i thought it would say "FOGS"
Thanks for any help.
-Wes
Old May 16, 2011 | 08:04 PM
herrschaft's Avatar
EDIT:
missed that part....
Updated post 4
Old May 16, 2011 | 08:23 PM
nghiars's Avatar
^^3?? i know theres one under the hood and one under the dash. Where's the 3rd box?
Old May 16, 2011 | 08:31 PM
herrschaft's Avatar
^There's 2 in the battery compartment, one in front of the battery and one behind it. The one behind the battery is right against the firewall and is a PITA to access. If you remove the passenger side cowling you will be able to see it. You may have to remove the battery to pull the fuses.
Old May 17, 2011 | 12:06 AM
Beebo's Avatar
does it say FOGS on the fuse box?
Old May 17, 2011 | 12:27 AM
herrschaft's Avatar
^ I've never looked at the labels before.
Old May 17, 2011 | 01:25 AM
Beebo's Avatar
lol yeah i cant seam to find them
Old May 17, 2011 | 02:49 AM
sTeadFasT96's Avatar
I can't remember if it says fogs, but it should say something to do with lights. It is a 15amp fuse and located behind the battery. You don't need to remove the battery, just remove all of the plastics around the battery, just pop a few clips and take off the fuse cover and you should be good.
Old May 17, 2011 | 02:51 AM
Beebo's Avatar
will do thanks
Kng0fHrts
Sep 15, 2015 05:40 PM
TheBay
Aug 27, 2015 05:08 AM
broke_as_ajoke
Aug 22, 2015 08:27 PM
Danielek
Aug 11, 2015 09:33 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
