G35 & G37, Coupes & Sedans
Question on nrg fender washer?
Old Jun 21, 2011 | 10:26 PM
amart014's Avatar
Ok so I assumed that these just thread through a hole with the included nut on the other side add some liquid weld and done. But this kit came with a hex bolt and sone sort of key. I have no idea what this is for. Any ideas?
Old Jun 22, 2011 | 06:20 PM
amart014's Avatar
Any ideas???
Old Jun 23, 2011 | 12:33 PM
JJSOLON's Avatar
Pictures would help...
Old Jun 23, 2011 | 09:36 PM
amart014's Avatar
Ok here's a pic of the bolt washer and nut... easy enough...
Wtf is this for?????
Old Aug 17, 2011 | 08:34 PM
IIIHawKIII's Avatar
you ever figure this out?
Old Aug 17, 2011 | 08:38 PM
JJSOLON's Avatar
It looks like u might have to pound those bottom metal piece in to the hole some how.
Old Aug 17, 2011 | 10:02 PM
DHCrocks's Avatar
That looks like a rivnut. You need a special tool that looks like a hand riveter to set it. It is used to put a threaded insert into sheetmetal so you can install a bolt without having to get access to hold the nut on the backside. The tool will squeeze the barrel of the rivnut and sandwich the front flange and back side so it is permanently installed. You then simply install the bolt into your new threaded hole.
Old Aug 17, 2011 | 10:10 PM
DHCrocks's Avatar
that looks like a simple manual setting jig for the rivnut. the black cylinder thing, does it have flat sides on the barrel so you can put a wrench on it? if so here's what you do.
  1. insert the golden looking thing into the hole all the way till the flange is bottoming out on the surface of the sheetmetal
  2. put the bolt thru the black cylinder and thread into the rivnut.
  3. make sure the rivnut is sitting all the way in the hole with the flange resting on the sheetmetal
  4. hold the back cylinder with a wrench and use another wrench to tighen the bolt. (this will pull the backside of the rivnut into the sheetmetal)
  5. tighen as hard as you can, you need to complely compress the rivnut.
  6. remove bolt and test your installation, the rivnut should not spin, if it does you need to tighten it more.
  7. if it does not spin you're done. you can install the new decorative bolt.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
PZ06G
Interior
Aug 24, 2015 06:27 PM
helalo
Aug 10, 2015 08:21 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
