G35 & G37, Coupes & Sedans
seat switches
Old Sep 12, 2011 | 05:03 PM
luisp88's Avatar
seat switches
i have a 04 coupe. the seat switches all work except for the 1 that makes the seat go up and down, it only works to raise the seat up and its stuck on that position ( very uncomfortable ). do I have to spend 1000$ on replacing the bottom of the seat or can I get switches exchange to fix the problem?
-luis
Old Sep 12, 2011 | 05:09 PM
simpson's Avatar
You can just change the switch. you take the seat out of the car. There is a black tape covering two screws. then you can unhook the plug from under the seat and change it out.
Old Sep 12, 2011 | 07:08 PM
jbell255's Avatar
^ WHS sounds like bad connection with switch if all the other movements are working.
Old Sep 14, 2011 | 05:29 AM
korb's Avatar
You may be able to take the switch apart and clean the metal contacts inside. Carbon buildup can result in the electrical current not connecting through when you use the switch.
I'd take the switch completely apart and examine the interior to check for carbon buildup before investing in a new switch. You will have to take the entire driver's seat out though. Search around, there are guides here.
Old Sep 14, 2011 | 01:58 PM
luisp88's Avatar
thanks for the responds sounds like something i'm going to tackle this weekend!
-luis
Old Sep 14, 2011 | 04:32 PM
bluedevils95's Avatar
let us know the out come of this when your done.
Old Sep 14, 2011 | 05:40 PM
simpson's Avatar
I don't recommend you taking the switch apart unless you know what you are doing.
These switches are not like any other. There is nothing inside the switch for you to clean. If you take the top off there Is two switches per one switch. There is a little ball bearing and Two tiny springs make sure you don't loose them. Then there is only one contact. So that is 4 springs and 2 ball bearings per switch.
Old Sep 14, 2011 | 06:26 PM
wolfpackdl90's Avatar
not trying to thread jack here, but i do have a similar situation as the OP here, except my driver side seat doesn't move at all and my tilt steering wheel function no longer works. Infiniti said it was an electrical issue and not a seat motor issue for the seat. they told me further diagnosis would be needed, and at 115 an hour i passed on it for the time being. would anyone have any type of insight on my issue and how i should proceed from here in diagnosis the issue myself potentially.....
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
doakley92
Sep 25, 2015 12:58 PM
