G35 & G37, Coupes & Sedans
what nuts, bolts, brackets, etc can i remove from the engine bay?
Old Nov 26, 2011 | 01:48 AM
funnyscreenname's Avatar
just wondering what all can be removed from the engine bay. i know many people lose alot of hosing, brackets, and such when doing wire tucks and all. i've never really seen exactly how people make it all look so clean and minimal. can someone help out on this.
Old Nov 26, 2011 | 01:55 AM
CandlestickPark's Avatar
ill Sedan
Everything that you don't see in this pic can be removed.
And I haven't even removed everything I could have (idler pulley, hose that connects to the OEM thermostat, AC line, main harness at the firewall, rear coolant bypass, etc.)
Old Nov 26, 2011 | 05:19 AM
bluedevils95's Avatar
So, your going to do this project for you car? WOuld be nice for you to do. You can start working on your car slowly if you like. No rush
Old Nov 26, 2011 | 12:10 PM
i'd like to clean it all up a bit. make it look more minimal. i'd like to get an oil catch can and also a ground wire kit. i really don't like the look of the ground wire kit. especially when it's colored. the bright wires just stick out and run everywhere. i want the positive results of the kits but, i'd like to have the wires look oem (black) and also not have them very noticeable. i'm not too sure how i'm gonna do this yet.
Old Nov 26, 2011 | 02:42 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
Here is a thread I made on Shane's grounding kit. IIRC Marcus (CsP) is running a custom one, hidden even after all the harnesses and hoses have been removed.
Old Nov 26, 2011 | 04:16 PM
drkay's Avatar
https://g35driver.com/forums/g35-sed...wire-tuck.html
Old Nov 26, 2011 | 04:33 PM
ill Sedan
Sean (SxExCx) made a newer version of his grounding kit that doesn't "stand out" as much as the first version. Very neat install. I used to have Sean's kit it was awesome.
re-crue13 is right, I do have a custom grounding kit because I didn't want any wires visible. Its only like 3 wires IIRC (RRDYE put it together for me when he did my wire tuck) and you will only notice them if I point them out to out in person, they don't show up in the pics.
Old Nov 26, 2011 | 04:35 PM
re-crue13's Avatar
Here's the link to said thread.
https://g35driver.com/forums/reviews/372850-sxexcx-v2-stealth-grounding-kit.html
Old Nov 27, 2011 | 12:56 AM
SxExCx's Avatar
Yes, I now make the V2 "stealth" kit which is barely visible once installed, especially when you order the flat black kit.
You can PM me if you are interested or have any questions.
Old Nov 27, 2011 | 07:59 AM
Blue Dream's Avatar
I drove ttrank's car solo
There are a couple of quick things you can do to clean up the bay w/o doing a full wiretuck. A RareJDM harness cover is a great start, remove 2-3 brackets that hold wires and harnesses and just tuck those under the cover. Also, I will second the V2 "Stealth" grounding kit from SxExCx and his aluminum PS and coolant overflow tanks. Kinda a crappy pic, sorry for that, but I have the V2 kit in blue and it's barely noticeable in the bay.
Show more
Old Dec 1, 2011 | 08:41 AM
NjMatteSedan's Avatar
Dont forget the AC line bracket
Old Dec 1, 2011 | 11:13 AM
Sent you a PM.
Old Dec 3, 2011 | 11:22 PM
TurboDreamzG's Avatar
What about the upper heater hose delete? I heard you can remove the hose that runs on the front of the engine but what do you use to "plug" where the hoses hook up to?
Old Dec 3, 2011 | 11:36 PM
ill Sedan
If you look at the photo I posted of my bay I've done the upper hose delete. I had both my drivers side and passenger side coolant pipes welded, that's the proper way to delete the hose. I've seen those rubber plugs go bad and leak.
Old Dec 7, 2011 | 11:00 PM
Michael Joneser's Avatar
What does that upper hose supply coolant to? I replaced mine with a silicone one that came with the Z1 silicone coolant hoses.
