G35 & G37, Coupes & Sedans
what nuts, bolts, brackets, etc can i remove from the engine bay?
Old Dec 7, 2011 | 11:06 PM
CandlestickPark's Avatar
ill Sedan
From what I understand it just makes the coolant system easier to bleed, you don't need the hose.
Old Dec 8, 2011 | 01:05 AM
SxExCx's Avatar
Samco now makes silicone hose caps so you can delete the upper hose without having to ever worry about it leaking.
Old Dec 8, 2011 | 05:24 AM
lsmooth81's Avatar
Nice, just did a quick search and came up with this. Sean can you verified for me if this is the correct size for our car.
http://racebikebitz.com/index.php?ro...product_id=590
Old Dec 8, 2011 | 06:11 AM
HotRodG35's Avatar
Originally Posted by Michael Joneser
What does that upper hose supply coolant to? I replaced mine with a silicone one that came with the Z1 silicone coolant hoses.
It bypasses the radiator and allows a portion of coolant flow directly from coolant return pipe to the water pump suction.
It allows for a quicker warm up of engine for emission purposes, this is why not needed especially in warmer climate areas.
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
hrdwirk1
Jul 14, 2015 05:46 PM
si_driver
Jul 14, 2015 12:29 PM
