G35 & G37, Coupes & Sedans
Dang Window!
Old Feb 7, 2012 | 07:14 PM
D87's Avatar
D87
Dang Window!
So I pulled the tint off the windows on my coupe and now the driver's side doesn't automatically go down a little when you open the door. I can gently push it down a little and if I do that, when I close the door it does automatically push the window up a little like it's suppose to. Anyone have a fix for this? Probably just lost some slack?
Old Feb 7, 2012 | 08:09 PM
NATH_19's Avatar
If I was on my laptop I could give you the direct link.
But do a search like power window or window reset. There have been multiple topics about this..so again search is your friend....
Old Feb 7, 2012 | 09:08 PM
bluedevils95's Avatar
I am guessing here because it happen to my friend. If you pulled the tint off the window might be sticky from the tent
Old Feb 7, 2012 | 09:32 PM
D87's Avatar
D87
Yep, already did the window reset, and it didn't fix it.
The window rolls up and down with no issue, it just won't roll down a little like it used to, so I don't think it's sticking.*
Anyone have experiences fixing this?
Old Feb 11, 2012 | 02:32 PM
flyz's Avatar
Mine also doesn't do this. Passenger side lowers but not driver's side
Old Feb 12, 2012 | 04:31 PM
D87's Avatar
D87
Dammit I was going to take the door apart to see if I can do anything about it but I've had bad luck taking things apart and not being to put them back together - and breaking clips.
After I open the door, I can hear the motor wanting to lower the window a bit, but it doesn't. So I manually give the window a gentle push and it goes down a little (the amount it should automatically), so it seems like something's not catching. When I close the door it does automatically roll it up that 1/2 inch.
My brain hurts...
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
