G35 & G37, Coupes & Sedans
Tire setup
Old Mar 7, 2012 | 04:08 PM
Tbyrd84's Avatar
Tire setup
Im getting ready to put axis shine.s on my car. 20x10 +20 in the rear and 20x9 +15 in the front.what size tires should i run because i want to put some springs and lower it. whats the best setup so they wont rub. 2004 g35 coupe non brembo
Old Mar 9, 2012 | 11:08 AM
raul87's Avatar
heres my setup it all depends what look ur going for
https://g35driver.com/forums/g-spot/...you-think.html
Old Mar 9, 2012 | 03:30 PM
Tbyrd84's Avatar
looks good, did you have to roll the fenders after you put the springs on
Old Mar 9, 2012 | 03:41 PM
raul87's Avatar
Yes I did but only the rear
Old Mar 10, 2012 | 09:29 AM
gary c's Avatar
With your 9" rims in front you can run either 245s or 255s, 10" rims out back 285s will fill that wheel. Depending on where you live having your back wheel lips rolled is easy if needed....with 20 offsets I don't believe you will.
Raul, with the massive arch on our front fenders I don't recall anyone having those rolled cause they already are....Gary
Old Mar 10, 2012 | 03:49 PM
Tbyrd84's Avatar
Now im looking at the Stance sc5 cant decide, yeah i live in Asheville Nc cant find anybody to roll the fenders, any diy suggestions because they just said to cut and bend them up
Old Mar 10, 2012 | 04:02 PM
gary c's Avatar
Go to Forums, then Regional and North America....look for your location. Find a sticky for Member Recommended Shops in your area. There should be someone in your area rolling fender lips. Only have this done if you need to, why waste the $$ if it doesn't need to be done with your offsets....Gary
Old Mar 10, 2012 | 05:00 PM
whoozyadaddy7's Avatar
Tbyrd- rolling fenders yourself really isn't too difficult. Down here in AZ the shops charge ridiculous amounts to roll fenders, I got quoted between 50-80 a fender. I did it myself using a baseball bat. It really is a feel thing to determine how much pressure to apply. Luckily I did it in the summer here so I had no need to use a heat gun to keep the paint from cracking, but make sure to apply heat to the area you're rolling to prevent nasty paint chipping. But like Gary said, if you don't need to don't bother. With a 285 tire you'll definitely need a roll IMO. I ran a 285 in the rear prior to coil over install on a 10" + 15 wheel and i hit. Now I'm lowered, running a 10.5 +22 wheel and 295 tires and I definitely need the roll.
Old Mar 11, 2012 | 03:26 AM
Tbyrd84's Avatar
Thanks everybody i appreciate the help on this
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
dougk12
Engine - Intake/Fuel
Mar 22, 2016 08:34 AM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
Spartan268
Aug 20, 2015 09:14 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
