G35 & G37, Coupes & Sedans
Oil change help
Old Mar 18, 2012 | 12:56 PM
  #31
CLEANBS's Avatar
I recently switched to GC 0w30 and I added 1 quart in 5k miles. Before using M1 5w30 I never had to add a drop.
Is this normal for 0w30? Or should I switch back to 5w30?
Old Mar 18, 2012 | 01:09 PM
  #32
bigc's Avatar
Wings Nation
Originally Posted by Deepdiver
Well George...I mean Garage...I'm glad I never took my car to your shop, cause you can't even read a simple table. You're confusing quarts with liters. I can't imagine all of the countless cars you've serviced putting in incorrect fluid amounts. How do you like them squirrels!!
Originally Posted by Garage Kansai
No I didn't confuse anything so you show me a owners manual and I provided actual spec sheets that say 4.7 qts.
Did you even look at the 2 charts I provided? They boyh clearly say 4.7qts
what?!?!?!?!?
Old Mar 18, 2012 | 01:10 PM
  #33
Deepdiver's Avatar
You're noticing a difference because the zero-30 in a thinner oil. It's not normal, but can occur with higher mileage engines due to worn rings, etc.
Old Mar 18, 2012 | 02:14 PM
  #34
prinny's Avatar
I've always used a little bit less than 5 quarts. I know it says 5, but it always seems a bit too full if I add in all 5. Never had an issues so it's okay I suppose lol.
Old Mar 18, 2012 | 02:27 PM
  #35
Deepdiver's Avatar
^ I always figured this was due to sludge buildup taking up space in the oil pan..
Old Mar 18, 2012 | 06:25 PM
  #36
Top Teke's Avatar
Originally Posted by ITNKICN
The adult female is probably laden and the juvenile unladen... Unless you're in the southern US... In which case the laws of probability insist that they are both- in all likelihood- laden.
Yess!! I knew someone would know. Now, if I can use squirrels to change my oil for me..
Old Mar 18, 2012 | 07:00 PM
  #37
prinny's Avatar
Really?
zoop425
Mar 29, 2016 05:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
