G35 & G37, Coupes & Sedans
Old Aug 18, 2014 | 11:21 PM
  #2446
TheJuice401's Avatar
thanks for the help all! on that note i just sent in a reservation a few hours back for the vanity plate "gcoupe" i had alot cooler names to pick but RI only allows 6 letters.
Old Aug 18, 2014 | 11:31 PM
  #2447
christopherv5's Avatar
Speaking of tickets,
I got my first ticket the other day for supposedly having my headlights off which i doubt bc they are always on auto. anyways, he wrote my age wrong, the model of my g wrong, and he wrote that i was the registered owner, which im not (my dad is for the lower insurance cost) anyways, can i dispute this?
Old Aug 18, 2014 | 11:43 PM
  #2448
ScraggleRock's Avatar
You can dispute anything.
Old Aug 19, 2014 | 09:48 AM
  #2449
JKL1031's Avatar
But you won't win!!
Old Aug 22, 2014 | 11:20 AM
  #2450
PLENUMCOUPE's Avatar
New hoses
Old Aug 22, 2014 | 12:22 PM
  #2451
Lartytiejdke3's Avatar
Originally Posted by PLENUMCOUPE
New hoses
you figure out the best way to take the old ones off?
How'd that go
Old Aug 22, 2014 | 12:53 PM
  #2452
Ha I figured out the real hard way. I honestly had no idea that coolant was running through them I thought it was just air like an idiot. So I pulled off the clamps on one and started tugging on the hose and it wouldn't come off so I took a razor blade to it and coolant started leaking everywhere so I was like ***. Zip tied it back together and drove to work with a lil smoke coming out but my temp gauge was fine. BUT, on the way home from work my temp gauge shot up and down and had to pull over b4 it overheated. Luckily 2 technicians at work live down the street from me and brought me coolant and then I made it home.
So for a DIY u gotta pull the stock hoses off and be ready for the coolant to go everywhere and drain out. Put the new ones on and make sure to get screw clamps Bc the silicone hoses are thicker then OEM and they didn't come with my mishimoto kit but they might come with samcos kit. Then refill the coolant with half water (distilled preferably) and half coolant. Run the car and bleed the system of air (u know it's done when u blow hot air in the cabin and it eventually warms up- it will be cool at first) then spray down the engine bay. Also u gotta unscrew the radiator fan and pull it up a bit as well as taking out the coolant overflow bottle to get to the bottom hose.
Moral of the story, it's kind of a big job.
Old Aug 22, 2014 | 01:14 PM
  #2453
Shanes_G's Avatar
Lessons learned though.
Old Aug 22, 2014 | 04:46 PM
  #2454
JKL1031's Avatar
I'm not touching my cooling system unless something breaks.
Old Aug 22, 2014 | 04:50 PM
  #2455
Frankieg35's Avatar
Yeah don't do it, go to the dealer or a shop, it's well worth it..
Old Aug 23, 2014 | 12:20 PM
  #2456
Ha I figured out the real hard way. I honestly had no idea that coolant was running through them I thought it was just air like an idiot. So I pulled off the clamps on one and started tugging on the hose and it wouldn't come off so I took a razor blade to it and coolant started leaking everywhere so I was like ***. Zip tied it back together and drove to work with a lil smoke coming out but my temp gauge was fine. BUT, on the way home from work my temp gauge shot up and down and had to pull over b4 it overheated. Luckily 2 technicians at work live down the street from me and brought me coolant and then I made it home. So for a DIY u gotta pull the stock hoses off and be ready for the coolant to go everywhere and drain out. Put the new ones on and make sure to get screw clamps Bc the silicone hoses are thicker then OEM and they didn't come with my mishimoto kit but they might come with samcos kit. (Mishimoto comes with 4 hoses and samco comes with 3). Then refill the coolant with half water (distilled preferably) and half coolant. Run the car and bleed the system of air (u know it's done when u blow hot air in the cabin and it eventually warms up- it will be cool at first) then spray down the engine bay. Also u gotta unscrew the radiator fan and pull it up a bit as well as taking out the coolant overflow bottle to get to the bottom hose. Moral of the story, it's kind of a big job.
thanks for that. Def is a big job
Old Aug 23, 2014 | 02:26 PM
  #2457
Frankieg35's Avatar
Put in my tokico shocks and eibach 350z spring.. It's sitting right where i want it too.. Might swap out the rear spring mount for an unmodded one next week when I do alignment, gotta see where the springs settle.. Going to do my front brakes and rotors in a bit whenever my buddy gets to his house, I'm waiting on his step like a retard.. haha
Old Aug 23, 2014 | 03:03 PM
  #2458
I wouldn't leave you out in the cold..
Old Aug 23, 2014 | 03:22 PM
  #2459
Hatchman's Avatar
Got my nifty shifty boot!
Old Aug 23, 2014 | 04:26 PM
  #2460
Frankieg35's Avatar
That's why u my bae!!
