G35 & G37, Coupes & Sedans
Old Mar 22, 2015 | 09:58 PM
  #4096
digital sol's Avatar
Originally Posted by DigitalDeviant
I am doing all whitelines as well. But instead of downtime, I picked up used knuckles, new arms and subframe to have powderd and bushings installed.
Side note: I did get my driver side lock actuator replaced. 2nd time in 3 years unfortunately, if it happens again ill be doing the 5$ fix for sure. Its a pretty big pita to replace those. And i need to reset the window switch still, it wasnt working properly and i had suspension stuff to attend to.
Yea in hindsight I would have gone that route for sure. I have had a lot of down time from this undertaking and its been a learning curve for sure. Pretty much any bolt or sleeve has been a pita due to rust etc. Even with air tools ive broken bolts and dealt with siezed bushings the whole way.
I am wondering if maybe a 2 or 3 leg puller would work to install the new bushings. I am going to pick up some 1.5" dom tubing tomorrow. Ill have them cut me some in 1, 2 and 3" pieces.
I also found this would would work if the sleeve is short enough on 1 side but its stooooopid expensive so not happening.
SP #11100
Not much space to work with in there.
Old Mar 22, 2015 | 10:09 PM
  #4097
Frankieg35's Avatar
Washed her today and finally got my rear seats / painted console in. Anyone ever remove the labels off the seat belts? If so, pic please.
Should of done the 350z black seatbelt guide also..
Old Mar 22, 2015 | 10:16 PM
  #4098
DigitalDeviant's Avatar
Do tell me more...
Old Mar 22, 2015 | 10:22 PM
  #4099
Mr. Brooks's Avatar
If you're too busy to drive it don't worry I can do that for you. I can run it as hard as you like And let my coupe rest.
Old Mar 22, 2015 | 11:51 PM
  #4100
Frankieg35's Avatar
Do tell me more...
The 350z has a black seat belt guide that should work, see if you can find one at turbo toys and try it..
Old Mar 25, 2015 | 06:48 AM
  #4101
jrandys's Avatar
Gave my car a good wash then detailed the engine bay a bit.
Old Mar 25, 2015 | 01:04 PM
  #4102
LoSt180's Avatar
Are you referring to the little arm coming off the pillar? I would LOVE to see if I can retrofit that thing. In my 06 coupe, the belt clips to the seat itself, no arm per se. Not bad, except I'm a short guy and it puts the shoulder strap up by my neck, bugs the crap out of me on long drives.
Old Mar 25, 2015 | 04:26 PM
  #4103
Kelly Boyd's Avatar
I saw a thread similar to this before. Pretty much familiar. Anyways, just a changed oil today
Old Mar 26, 2015 | 03:22 AM
  #4104
Frankieg35's Avatar
Yeah, i dont see why it wouldnt work..
Old Mar 26, 2015 | 09:03 AM
  #4105
JKL1031's Avatar
Hate that darn thing..
Old Mar 26, 2015 | 10:13 AM
  #4106
Why wouldn't a 2005 seat belt work? Mines not attached to the seat like the 2006.
Old Mar 26, 2015 | 11:35 AM
  #4107
Urbanengineer's Avatar
Lol I never realized it was like that in the 03-05!
Old Mar 26, 2015 | 01:14 PM
  #4108
roddrick's Avatar
I was able to install my rare jdm harness cover.Next i'll start polishing the manifold and the timing cover.
Old Mar 26, 2015 | 01:51 PM
  #4109
ronnieballgame's Avatar
Looks good, good luck with polishing too. When I installed my harness cover, I thought the metal would be a little less flimsy, curious to get your take on it.
I'm thinking about going to a CF half engine cover as it will hide the timing cover. I don't have the patience or skills to polish it.
Old Mar 26, 2015 | 02:47 PM
  #4110
roddrick's Avatar
thanks, it's definitely flimsy. I honestly expected it to be better quality, but i guess it's not to bad for the price.I considered going with a CF engine cover myself, but i didn't think it would fit with my gt spec tower brace
